Basa Strip, I have attached a led lighting, will anything happen?
08.05.2020 17:51 # 1
Ssedo
I installed a 1.5 meter led strip, it works smoothly, the lights multiply when I hit the bass, but my question is; will it be a problem? Is there anyone who knows if the amplifier damages the sound system?
08.05.2020 17:51 # 2
Alicilik
I'll give it to my teacher. You can damage the output of the amplifier that burns the leds at high volume.
My suggestion is that if you have a blank sound output, you can enter it with a transistor or you have sound sensors.
[TUBE] 3nwfwtouqqg [/ TUBE]
08.05.2020 17:51 # 3
Ssedo
There is quite a lot of output in the amphitheater, I do not understand where we will get the output :) Best of all I am a kurca, did not put on the key, I rarely turn on the led :) What is the name of the sound sensors, where can I get it.
08.05.2020 17:51 # 4
error
In fact, you can use it in your bass output, if you use a capacitor such as 63 (or more) volt 1 microfarate in series to protect the system in front of the leds, it will not be a problem. error 2013-08-05 21:22:01
08.05.2020 17:51 # 5
Ssedo
Capacitor incident came to my mind, teacher, I will cut one of the cable you call serial and connect the capacitor. CryBig smile
08.05.2020 17:51 # 6
error
It is beneficial to keep the capacitor's voltage high and its capacity low ... going out to the leds ...
There are also very nice led stickers with their own sensor microphone, which works independently from the sound system, as their friend says, I suggest you to review it, they sell around 20 30 pounds.
[TUBE] 5gxaonvgsb8 & feature = share & list = PLDD6A34CC9C2B3D2 A [/ TUBE]
error 2013-08-05 22:19:20
08.05.2020 17:51 # 7
Ssedo
Sir, I put on the key, thank you for the information you will put on the capacitor in 3-4 days, it was nice, I guess we did not go into so much opener mode: D
Link video
08.05.2020 17:51 # 8
Gokhan Cetin
I have been using this style for 2 + 1 in my home for about 5 months.
08.05.2020 17:51 # 9
error
[QUOTE = Gökhan Çetin] I have been using this style for 2 + 1 in my house for about 5 months.
This type of thing does not cause problems in low power systems, but in systems with high output power, the leds may deteriorate and shorten the output to short circuit, which can damage the output of the amp.
Protection is provided with a capacitor, even to a small extent.
08.05.2020 17:51 # 10
Ssedo
I understood, thanks, teacher.
