BAS SET
08.05.2020 20:41 # 1
hulya1558
Hi
I have a pejo 206 speaker, I have a 1000 amp amp bass tapes made a tape recorder but I can't turn up a lot of sounds bass hit a lot lg tape brand how do I set this up a few times this time i broke the other settings? can you please help? Bass hits a lot even at 9 + 10 volume Smile
hulya1558 2017-12-13 11:32:56
08.05.2020 20:41 # 2
lg which model is hulya lady. ? I hope this user manual will work for you.
08.05.2020 20:41 # 3
RP393
Hello there,
The amp has HPF / FULL / LPF settings. Set the side of the bass connected (writes as front or rear) to LPF. Bring the speaker to HPF on the connected side.
If you write the brand model of the amp, the problem can be solved more easily.
08.05.2020 20:41 # 4
hulya1558
okay, nice thanks, the pages are crooked bass setting nerdee
08.05.2020 20:41 # 5
hulya1558
What do you say I will do over the top of the trunk attached in the trunk?
08.05.2020 20:41 # 6
ggitaristt
Bring the bass "+12 0 +6" db on the amphitheater to the "0" bass will decrease the bass (decreases to the level it should be normal). tamper the speaker side, as far as I understand you don't understand at all .. Big smile
08.05.2020 20:41 # 7
hulya1558
I don't understand why if I understand why I am here Embarrassed
08.05.2020 20:41 # 8
maximusti
Is there a subwoofer in the vehicle?
And if you say I can adjust the amp, I will describe it in detail.
08.05.2020 20:41 # 9
hulya1558
war yes there is no space in the 1000 trunk trunk because of them
08.05.2020 20:41 # 10
maximusti
can you find the brand model of the amp, it writes on almost all of them.
08.05.2020 20:41 # 11
hulya1558
ok let me write
08.05.2020 20:41 # 12
hulya1558
amfide by as604 channel hing pover amplifier
Kenwood writes in the big colon
08.05.2020 20:41 # 13
maximusti
[QUOTE = hulya1558] amphide by as604 channel hing pover amplifier
kenwood writes in big column [/ QUOTE]
from this amp?
08.05.2020 20:41 # 14
hulya1558
[QUOTE = maximusti] [QUOTE = hulya1558] amplifier by as604 channel hing pover amplifier
from this amp?
[/ QUOTE
the picture is not visible
08.05.2020 20:41 # 15
hulya1558
I took a picture but the picture is not taken ?? hulya1558 2017-12-15 13:46:56
08.05.2020 20:41 # 16
[QUOTE = hulya1558] I took a picture, no picture is thrown ?? [/ QUOTE]
Your pictures will be displayed if you upload the quickresim.com.
08.05.2020 20:41 # 17
hulya1558
there is no
by friend whatsaptan does not appear from here!?
08.05.2020 20:41 # 18
[QUOTE = hulya1558] does not disappear
by friend whatsaptan does not appear from here!? [/ QUOTE]
If you want, send the picture to sonerkyl@gmail.com I can upload it if there is no problem in you.
Actually, tell me that I have installed quickresim.com and then gives links. for example
If you copy and paste it at the beginning of the link with [url = https starting with these characters, you will upload it.
sonerkyl 2017-12-15 14:18:04
08.05.2020 20:41 # 19
hulya1558
[QUOTE = sonerkyl] [QUOTE = hulya1558] does not disappear
Okay, I took a picture with the mail.
08.05.2020 20:41 # 20
Page : / 2
