Bar front + rear logo attached (pictures at the 2nd bottom)
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:16 # 1
I disassembled the back lion, I liked it now, but now I have no idea how to disassemble it? it seems like there is a little paint difference underneath but there is no paint in my car as far as i know what is the reason? us HuseyinTurk2011-11-01 15:42:16
08.05.2020 16:16 # 2
metin
hüseyin's paint difference arises from the fact that the paint on the vehicle becomes dull in the sun over time, and the paint under the post remains as it was on the first day.
& nbsp;
If the baggage was already painted, the articles would be removed and painted (:
08.05.2020 16:16 # 3
metin
Now I have looked at the opposite of what I said, I couldn't make sense of it, it seems that the varnish was probably removed.
08.05.2020 16:16 # 4
[QUOTE = text] The difference in paint is due to the paint on the vehicle getting dull in the sun over time and the paint under the post remains the same as the first day.
& nbsp;
If the baggage was already painted, the text would be removed and painted (:
& nbsp; in my opinion, brother adaptation is ensured over time, summer months are closed for a few months and I wait for the rate to be brooded with a few months & nbsp;
08.05.2020 16:16 # 5
[QUOTE = text] I looked at it now, it was the exact opposite of what I said, I couldn't make sense, it probably seems that the varnish was removed. lighter color & nbsp;
08.05.2020 16:16 # 6
Brother, you can clean that article with the pitch remover without damaging the paint, the child I bought in the previous hawk has written 3.0 Turbo text & nbsp; "Grin" I pulled it up like this, no gram marks left. You squeeze and wait for a while, then lightly oval, it turns out and shines on the surface a beautiful & nbsp; "Laugh"
08.05.2020 16:16 # 7
metin
[QUOTE = HuseyinTurk] [QUOTE = text] I just looked at the opposite of what I said, I couldn't make sense, probably the varnish seems to have been removed. [/ QUOTE]
paint that buffer was painted later, lighter & nbsp;
& nbsp;
I say varnish. Because when painting the laths in my own car, when the paint was finished, it had nothing to do with the color of the car. When I took the varnish, it became the same color as my car. There is such a difference as it throws varnish on you. It does not easily varnish, but. Do you have paint on the tailgate? Generally, the parts painted later throw the varnish more easily.
08.05.2020 16:16 # 8
Why did you dismantle the articles for painting or boredom, by the way, you painted the lion anyway, but there is a tape in between?
08.05.2020 16:16 # 9
metin
[QUOTE = csalli] Brother, you can clean that post with the best remover and without damaging the paint, the child I bought in my previous hawk has written 3.0 Turbo text & nbsp; "Grin I pulled it up like this, no gram marks left. You wait tight for a while, then lightly oval, it turns out and shines on the surface a beautiful & nbsp; "Laugh" [/ QUOTE]
& nbsp;
I heard those who removed things like bitumen with margarine oil, it hurts, then you wash and wipe it all right.
08.05.2020 16:16 # 10
metin
[QUOTE = HeRo1727] Why did you remove the texts to paint or boredom, by the way you painted the lion, but there is a tape in between?
There will be something intersecting, or you will throw them all out and put the originals again.
08.05.2020 16:16 # 11
I wish hüseyin I wish ... you did the wrong job & nbsp; "grin" now you have done your work per stop
08.05.2020 16:16 # 12
sedataksu
Wd 40 frequently wait for 0n minutes to remove the text, then delete it will be clean. It is tried to recommend to friends who have bitumen stains in the car. width = "18" border = "0" alt = "Grin" title = "Grin" />
08.05.2020 16:16 # 13
[QUOTE = text] [QUOTE = csalli] My brother will clean that post with the best remover and without harming the paint, the child I bought in the previous hawk has written 3.0 Turbo text & nbsp; I just pulled it off, no gram marks left. You wait tight for a while, then lightly oval, it turns out and shines on the surface a beautiful & nbsp; "Laugh" [/ QUOTE]
& nbsp;
When you have bitumen, the bit remover works. It works well, especially when very small pieces are left.
08.05.2020 16:16 # 14
vd40 doesn't do anything to paint, right?
08.05.2020 16:16 # 15
sedataksu
[QUOTE = HuseyinTurk] vd40 does not do anything to paint, was it [/ QUOTE]
Suziki had a vehicle under waist was a complete pitch, I did nothing to paint. WD 40 lubricant and softener.
08.05.2020 16:16 # 16
[QUOTE = text] [QUOTE = HuseyinTurk] [QUOTE = text] I just looked at the opposite of what I said, I couldn't make sense, most likely the varnish seems to have been removed. [/ QUOTE]
No, the paint is getting dull from the sun, so the buffer was painted later and the color is lighter & nbsp;
& nbsp;
I say
varnish. Because when painting the laths in my own car, when the paint was finished, it had nothing to do with the color of the car. When I took the varnish, it became the same color as my car. There is such a difference as it throws varnish on you. It does not easily varnish, but. Do you have paint on the tailgate? Generally, the parts that are painted later throw the varnish easier.
Did you throw the varnish yourself, if I throw it in the complete car, what would the cost be? div>
08.05.2020 16:16 # 17
sedataksu
[QUOTE = HuseyinTurk] [QUOTE = text] [QUOTE = HuseyinTurk] [QUOTE = text] I just looked at the opposite of what I said, I couldn't make sense of it, it probably seems that the varnish was removed. [/ QUOTE]
No brother is getting dull from the sun, this paint is buffer afterwards, the color is lighter & nbsp;
& nbsp;
I say varnish. Because when painting the laths in my own car, when the paint was finished, it had nothing to do with the color of the car. When I took the varnish, it became the same color as my car. There is such a difference as it throws varnish on you. It does not easily varnish, but. Do you have paint on the tailgate? Generally, the parts that are painted later throw the varnish easier.
Did you throw the varnish yourself, if I throw it in the complete car, what would the cost be? div> [/ QUOTE]
Calm brother don't get into varnish business, everyone can not grin. You have to return no pain. If not, you can paste the letters again.
08.05.2020 16:16 # 18
metin
[QUOTE = HuseyinTurk] [QUOTE = text] [QUOTE = HuseyinTurk] [QUOTE = text] now I have the opposite of what I said. I call it a lighter [/ QUOTE] varnish. Because when painting the laths in my own car, when the paint was finished, it had nothing to do with the color of the car. When I took the varnish, it became the same color as my car. There is such a difference as it throws varnish on you. It does not easily varnish, but. Do you have paint on the tailgate? Generally, the parts painted later throw the varnish easier. [/ QUOTE] Did you throw the varnish yourself? If I throw it in the complete car, what would the cost be? Can I treat the accident vehicle afterwards? [/ QUOTE] yes I got it, you have to remove the varnish on the part completely. I think it is impossible to apply varnish to a small area locally, it depends on the country. The little barrier threw on the back door, the master said to be completely varnished, it will be painted, I did not get it, I do not expect it to be blown well (: it becomes matt when it is not painted, so the work is not in the paint, but in the varnish, this is painted but not varnished, you can look for example,
08.05.2020 16:16 # 19
emin08
You can remove similar stains, including tar, with kerosene. I even clean the car with gas oil. resin, bitumen, etc. adhering to the paint instantly removes them all and there is no harm to the paint. on the contrary, it polishes like polish. & nbsp;
08.05.2020 16:16 # 20
[QUOTE = emin08] You can remove similar stains including bitumen with kerosene. I even clean the car with gas oil. resin, bitumen, etc. adhering to the paint instantly removes them all and there is no harm to the paint. on the contrary, it polishes like polish. & nbsp; [/ QUOTE]
You will drive the gas oil under the sun and leave it in the sun. kinds of bars that I sell.
Page : / 3
