ball sound from under the vehicle
08.05.2020 14:51 # 1
Under my 2004 mod gasoline 307 vehicle, there is an unsoiled ball sound that goes to the clutch pressure from the engine part .. the master says you think .. what do you think?
08.05.2020 14:51 # 2
hasimayaz
It looks like a clutch ball. gotta look .. isn't pedal sound? pressure constantly sounds?
08.05.2020 14:51 # 3
Hasim Bey presses the clutch and the sound is cut off. I changed the clutch set in the service 5 thousand km ago, before I changed it, it was there.
08.05.2020 14:51 # 4
peugeotefe
There is a problem with socket pole ball
08.05.2020 14:51 # 5
okankrgz
can it be from the hoop?
08.05.2020 14:51 # 6
hasimayaz
Does it sound when the gear is released by pressing the clutch?
08.05.2020 14:51 # 7
no no sound coming in gear ...
08.05.2020 14:51 # 8
hasimayaz
There is a shortage in the primary gear or bearing. The transmission seems to need to be opened. In the market, socket socket ball passes as well.
08.05.2020 14:51 # 9
seLim
Could [QUOTE = okankrgz] be from the hoop? [/ QUOTE]
Embarrassed He said the hoop, or there is no solution for your problem. Kahkaha
08.05.2020 14:51 # 10
Thanks to everyone who comments. we'll open the gearbox and see what happens. The master says it starts from 400 TL. It is unclear whether the closed box chick will be bird.
08.05.2020 14:51 # 11
TOLGA
I had the same problem,
returning from the meeting tonight, the clutch was scarce in the village,
We did it temporarily, it is good if I go to work tomorrow without being on the road,
I would say, without neglecting and without me on the road,
08.05.2020 14:51 # 12
deniz_206
[QUOTE = TOLGA] I had the same trouble,
In the meantime, let's get past tolga brother.
