bad thermostat damages
08.05.2020 15:27 # 1
106_arts
my friends thermostat of my car is defective so open water is constantly circulating
what are the damages of this
overheat 70i
I went to the master, summer came and said he was good
I went to another master, he said the same room :)
I couldn't find the part in Nigel anyway.
08.05.2020 15:27 # 2
metin
your fuel increases. The engine has a certain temperature and runs by consuming more fuel until it reaches that temperature. The thermostat closes the circulation so that the engine reaches the required temperature as soon as possible.
In other words, it keeps the engine at the required temperature level by making it on and off. both the best combustion and the fuel goes down to the minimum level.
08.05.2020 15:27 # 3
106_arts
I think it burns a lot and the performance is lost _? 70i does not pass, if I tighten a little, 80e comes out, if I stop and get up 85 85 90 but it falls back instantly
08.05.2020 15:27 # 4
does not heat heating in winter
08.05.2020 15:27 # 5
Even if it does not cause much trouble in the summer, you will experience a lot of trouble. In general, the engine increases in its fuel, as long as it is at the back of the engine when it is operated with low heat.
you should replace it with the original at a convenient time ... at least until last spring :))
08.05.2020 15:27 # 6
106_arts
Will it damage the pump because it makes continuous circuit drips?
08.05.2020 15:27 # 7
maestro
How much money did this thermostat get past?
08.05.2020 15:27 # 8
106_arts
29 lira or something on the internet
08.05.2020 15:27 # 9
[QUOTE = 106_arts] will it damage the pump because it makes a continuous drip [/ QUOTE]
Well, what am I going to say? Do you think there is no circulation when the thermostat is closed ??? Sırıtma
As long as the engine runs and freezes the crankshaft, the circulation pump freezes continuously as long as the crankshaft freezes the triger apricot. If the thermostat is turned off, the heated water is circulating from the heater core inside the vehicle. Whether it is a thermostat or not, it does not matter whether it is closed or not ...
08.05.2020 15:27 # 10
[QUOTE = 106_arts] 29 lira or something on the internet [/ QUOTE]
yes he is around. I recommend you buy and wear the original. The original should be 89C. besides, it does not drop the engine below 90C. the text remained hungry on my brother's car. When he changed, he was like a stapler. it should be that way
by the way what was your vehicle ??? What happens if you write your brothers water brothers info ???
the cecol 2011-05-21 13:26:17
08.05.2020 15:27 # 11
cerci07
There is no harm in the summer, you will change it when the weather is cold right.
08.05.2020 15:27 # 12
se®k@n
I have been using the temperature indicator the same as you say for 1.5 years, I have never seen any damage or negative side of it. At first, I was stuck in your head like you .. The man I didn't ask was left. All checked, he said nothing. se®k @ n 2011-05-22 01:21:40
08.05.2020 15:27 # 13
ose
[QUOTE = se®k @ n] I have been using the temperature indicator the same as you say for 1.5 years, I have not seen any damage or minus in any way. .. Everything is normal .. I was stuck in the head like you in the first place .. The man I didn't ask was left .. All checked, he said nothing will happen .. [/ QUOTE]
Is there no problem in heating heating? then your temper should not be defective?
08.05.2020 15:27 # 14
helot
Does the temperature indicator have to stop at 90 when going the long way?
08.05.2020 15:27 # 15
ose
[QUOTE = helot] over temperature indicator, does it have to stop at 90 at long distance? [/ QUOTE]
If the weather is cool, it will not stop completely, it will stop at a little below 80 or so. finds 100 while climbing uphill
08.05.2020 15:27 # 16
helot
I was wondering if it was just under 90. Thank you.
08.05.2020 15:27 # 17
106_arts
right now my heater is blowing hot normal
08.05.2020 15:27 # 18
se®k@n
[QUOTE = kankam_743] [QUOTE = se®k @ n] I have been using the temperature indicator the same as you say for 1.5 years, I have not seen any damage or minus part of it anyway .. Everything is working well .. Very little fuel, my performance there is no fall .. Everything is normal .. I was stuck in the head like you in the first place .. The man I did not ask was not left .. All checked, he said nothing will happen .. [/ QUOTE]
As I said; everything as it should be .. There is no problem, thank god .. Gülme
08.05.2020 15:27 # 19
Melih
I wonder if I heat it up in my vehicle even after 70 80 minutes.
08.05.2020 15:27 # 20
mdincer34
It is best to change a very cheap piece, and the engine will work with cold water continuously, and after a long period of use, the damages will become more evident. not to take it to the master who says it will not do any harm :)
Page : / 2
