BACK FROM BACK?
08.05.2020 15:04 # 1
albay32
THE FRIEND OF THE FRIENDS OF MY CAR IS THE CONTINUOUS VOICE TO BE CONTINUOUSLY THE MOTOR IS TORSION OR I CAN BE AN AMTURATOR THE VEHICLE IS RELEASING TO THE RIGHT WHEEL IS RELEASING TO THE RIGHT, WHICH IS RELEASING TO THE RIGHT OF THE VEHICLE
08.05.2020 15:04 # 2
What is your vehicle, teacher?
If you want to look at the traverse bushes.
08.05.2020 15:04 # 3
albay32
2002 1.4 colorline gasoline
08.05.2020 15:04 # 4
albay32
Is this an expensive piece of traverse horoscope? is not a shock absorber
08.05.2020 15:04 # 5
No, it is a different piece. It has a price of around 250 TL. The rattling brings to mind the traverse bushes. But if the shock absorbers are intact, of course. If you hear tough sounds like "lok" "lok", look at the shock absorbers too. You can control the shock absorber too.
the laedr 2011-02-03 16:48:08
08.05.2020 15:04 # 6
dinoco
check in the trunk lock
08.05.2020 15:04 # 7
entrophy
Yes, since the hood's lock striker is plastic, it can wear out over time and can be clicked.
08.05.2020 15:04 # 8
ali oncu
it was coming from my luggage as well :)
08.05.2020 15:04 # 9
tugrahan
it was coming from the left back wheel in me
when you look at it
It was understood that the amateur was dead when the amateur didn't work
the master puts the load on torsion, said the master will change the torsion bearing
but I only got an amateur
monroe gas sound cut off
08.05.2020 15:04 # 10
[QUOTE = tugrahan] was coming from the left back wheel in me
when you look at it
How much money did you get for the monroe gas-powered rear shock absorber kit?
08.05.2020 15:04 # 11
peugeotefe
The shock absorber's bushing may be out of place. I recommend you look at it first, then the torsion is checked if the sound is not cut again.
08.05.2020 15:04 # 12
3rkans
Once we said the sound was coming from behind, the sound came out from the front rot arms.
