Back Door Seals (resolved)
08.05.2020 17:11 # 1
yenice
Greetings to everyone.
Friends, winter has come and the invisible problems have become evident :)
I am bored, in rainy weather, water is accumulating at the bottom of the door, on the steps. The water accumulated here also leaks inside. Excessive water accumulates on the mats. This problem is only happening at the back doors.
The rovings have changed before, no cracks break out. It is said that there is only a cut, not a whole, as a sub-industry.
Can I find the original wick or is there a solution according to the current version? serum hose etc. I have some feelings.
Thanks for the help.
yenice 2012-12-10 11:08:50
08.05.2020 17:11 # 2
Bugra
The original 206 rear door is about 66 pounds on the market. of course a door and original.
08.05.2020 17:11 # 3
feline
hoot yahu how expensive
08.05.2020 17:11 # 4
yenice
Yes, I found it on a site today says original. 66TL for the rear doors, 80TL for the front doors :) The only price is not set :)
08.05.2020 17:11 # 5
fxmen
my friend had the same problem on me on the day of the market, I was ten passenger seats, it was filled with water. I would advise you to check on the side battens
you can examine the messages in the law that I hurt.
[QUOTE = mev347] water enters the holes of the side door slats. water is coming in through that hole. My advice is to ensure the waterproofing of the door slats. I write it as someone who happened to me ... :) [/ QUOTE]
http://forum.peugeotturkey.com/forum_posts.asp?TID=25902&title=206-su-ald
08.05.2020 17:11 # 6
yenice
Suppositories came, we just put on. but the result is the same friends.
I held the hose from the top and did not enter the right door. Then I took the car halfway on the sidewalk and entered the right door, with the right wheels on the pavement. /b1209.hizliresim.com/11/j/d3b3d.jpg "border =" 0 "/>
yenice 2012-12-07 17:01:00 < / editdat a>
08.05.2020 17:11 # 7
fxmen
It is very annoying, my friend, my god, patience, I think that whenever it rains, I think that I bought water all day, I think that I do not see it, when I come home, I immediately go to the car and see it. I'm getting out :) I guess you will have to hand over the side bolts.
fxmen 2012-12-07 22:49:11
08.05.2020 17:11 # 8
yenice
The place I marked in red, that is, just below the interior door trim, when I close the door on the wick, that is, it coincides inside.
We thought the water would enter from here.
When removing the inner door trim, there is a white foam inside the door that wraps around the door. That foam needs to be adhered to the sealant from the edges.
The sealants of the lower part have lost their adhesiveness and discarded. The water taken from the outer side of the glass wicks into the door goes through the drains but also leaks inside.
We solved the problem by sticking the foam in the floor with mastic ..
08.05.2020 17:11 # 9
fxmen
I'm glad for you & nbsp;
08.05.2020 17:11 # 10
Bugra
Meanwhile, the wheels are hot. what is your tire size 195/50/15?
08.05.2020 17:11 # 11
yenice
[QUOTE = fxmen] I'm glad for you & nbsp; [/ QUOTE]
08.05.2020 17:11 # 12
yenice
[QUOTE = bugrature] wheels are now in the meantime. What is your tire size 195/50/15? [/ QUOTE]
195 - 45 - 16 tires. it was like this when I bought it.
08.05.2020 17:11 # 13
Serkan
You have solved it well Ramadan, glad
08.05.2020 17:11 # 14
svgkhn
Let my brother get past, but nevertheless, a proposal has changed the outer wicks, it takes the water from the top of the door and the lock ends on the side, and let it down.
08.05.2020 17:11 # 15
Mami86
They said it before me; How beautiful are the rims ... :) Do you know what the name of this model is?
08.05.2020 17:11 # 16
yenice
[QUOTE = Mami86] They said it before me; What are the rims beautiful ... :) Do you know what the name of this model is? [/ QUOTE]
http://forum.peugeotturkey.com/forum_posts.asp?TID=24801&title=finally-bitti-images-added
Alicin stated this issue, as 206's own model. I was on it when I bought the car.
I do not know about the rims alone, light right and left pull, the steering has problems in its own pickup, there is no problem in the front set, everything is new and smooth, the wheels are said to be heavy.
yenice 2012-12-16 16:19:44
08.05.2020 17:11 # 17
Bugra
When it comes to picking, is the steering wheel heavy? Are you turning hard? pull is not from the rims. look at the emergency rod setting or if the wires of the tires can be waste way tires. I also have 16 steel wheels, 195/45/16 tires. & nbsp; I fitted the car with a hair rim and a 175/65/14 orig winter tire, making the steering a bit lighter. I had a pull too. it was right to the right. we changed the front tires left and right, this time started pulling to the left. said the master from the tires. I changed neither pull nor anything. Don't let the tire tricks fool you. Even if it looks like new, the wires have gone from the inside.
08.05.2020 17:11 # 18
yenice
[QUOTE = bugrature] When I say addition, is the steering wheel heavy? Are you turning hard? pull is not from the rims. look at the emergency rod setting or if the wires of the tires can be waste way tires. I also have 16 steel wheels, 195/45/16 tires. & nbsp; I fitted the car with a hair rim and a 175/65/14 orig winter tire, making the steering a bit lighter. I had a pull too. it was right to the right. we changed the front tires left and right, this time started pulling to the left. said the master from the tires. I changed neither pull nor anything. Don't let the tire tricks fool you. Even if it looks like a new one, the wires have gone from the inside. [/ QUOTE]
We have done all of the tires on the right, left, front, etc. Even though the ball was balancing, I just got in.
But the tire was improved when it increased the air a little. The problem of picking is like this. for. It doesn't just get stuck like a pile, but it does not collect, only light support is required.
08.05.2020 17:11 # 19
KenBlockJR
[QUOTE = yenice] [QUOTE = Mami86] They said it before me; What are the rims beautiful ... :) Do you know what the name of this model is? [/ QUOTE]
there is nothing because the wheels are heavy, these are the original 206 wheels. Have your rot-balance settings checked.
08.05.2020 17:11 # 20
KenBlockJR
I have not seen the previous message. then there is trouble in the steering pump. & nbsp;
