axle change rod adjustment
08.05.2020 19:02 # 1
slayer65
friends, I changed the axles of my car, do I have to enter the rot setting, thanks again in advance good forums
08.05.2020 19:02 # 2
muro_60
No need if you haven't touched the rot heads, see the road on the road again.
08.05.2020 19:02 # 3
slayer65
as if there is an abnormality in driving in no pull, the left wheel knocks itself to the left
08.05.2020 19:02 # 4
muro_60
[QUOTE = slayer65] as if there is an abnormality in driving with no pull, the left wheel knocks itself to the left as if [/ QUOTE] hurts a bit.
08.05.2020 19:02 # 5
slayer65
The left wheel pulls itself to the left, as if the steering wheel is going to the left, I sometimes feel the brake while holding the vehicle to the left, but it stops, but there is no deflection when I release the steering wheel of the car.
08.05.2020 19:02 # 6
muro_60
[QUOTE = slayer65] The left wheel pulls itself to the left as if the steering wheel is going to the left occasionally while I am holding the brake, I feel forced to the left, but there is no deflection when I leave the steering wheel of the car. you bought my press had left stream 1cm long gone out I had to bring an orig from the service
Is there a tremor in sudden departures
