awkward
08.05.2020 17:06 # 1
sansasyon61
If I said it was a problem since April, when I bought the car, I did not leave anything else, but let me tell you that when the vehicle is in 1st gear, I pull my foot out of the gas and it starts to decelerate, like engine braking.
08.05.2020 17:06 # 2
hsnsnl
I think that without seeing this, the brakes of the vehicle that should be looked after may be tight .. If the vehicle passes on a flat road for a certain km & nbsp; the gear is empty .. If your vehicle loses its speed excessively, there is no problem if it loses at a normal level .. & nbsp ; your vehicle's compressor is beautiful because of this .. & nbsp; there is no problem with your vehicle .. just maintain it :)
08.05.2020 17:06 # 3
feline
When it comes to the floor, it cuts. Normal 1st gear is for lifting purposes only
08.05.2020 17:06 # 4
sansasyon61
Well, if the service is not goturn in this regard, does no problem do it do the crank pulley?
08.05.2020 17:06 # 5
sansasyon61
you have the brakes, you can be tight master, for example, I have something, I changed the car's pads and discs 8 thousand km ago, I made a sound since I bought it for the first time.
08.05.2020 17:06 # 6
What are you doing in 4th gear at 4 thousand cycles? brokerage in. Reviews
08.05.2020 17:06 # 7
sansasyon61
:) I gave him an example at the master, but at 3000, this is what I said :)) it is good to have a little shout.
08.05.2020 17:06 # 8
seyyah
Motor compression is what you mentioned. If it does, it indicates that the engine is in good condition.
08.05.2020 17:06 # 9
sansasyon61
ooo, thank you, I don't have to worry.
08.05.2020 17:06 # 10
badcombatant
If you suddenly pull your foot out of the gas even at 2000 revs in 1st gear, it is quite normal for the car to accumulate or slow down 2-3-4-5. You will experience the same thing at slightly higher speeds in gears. I think it is normal to react in this way by pulling the foot of the diode from the gas to the gearbox that produces the torque and the movement of the vehicle as soon as you press the gas. You may not feel it in high gears, but you will experience the same event.
08.05.2020 17:06 # 11
sansasyon61
it is understood that the masters are saying no problem :)
08.05.2020 17:06 # 12
peugeotttt
Is it normal that my gti does not speed more than 100 km in 2nd gear: D
08.05.2020 17:06 # 13
sansasyon61
: Well, I haven't tried doing how many, but it doesn't do that much & nbsp;
08.05.2020 17:06 # 14
peugeotttt
: You try DD, mine is mine, after 100, I don't have a bad air filter.
08.05.2020 17:06 # 15
sansasyon61
Let's not take the engine into the lap after I try 100: D
08.05.2020 17:06 # 16
peugeotttt
Nothing will happen: D: D anyway, good luck to you, I will run away from the rain in the rain, with some gti.
08.05.2020 17:06 # 17
sansasyon61
:)) be careful ustad you are not injured good luck :)
08.05.2020 17:06 # 18
deme
is normal no problem
08.05.2020 17:06 # 19
tellotello
Since it is a situation similar to a friend, let me ask about the situation here as well: if I pass from 1 to 2, after passing the gear and pulling my foot from the clutch, it is as if the engine brakes, it acts like a vehicle, then acts normally. In high gears, this is not the case, but when moving from 1 to 2 and 2 to 3, the engine is braking first and then it continues without any problems. What could be the reason for me? Thanks ... Reviews
08.05.2020 17:06 # 20
sansasyon61
I am asking here for not to make a new subject, my friends, I heard the sound of the sofor seat.
Page : / 2
