Aux speaker problem
08.05.2020 20:33 # 1
Furkan979
You know, guys, I opened the aux yesterday, but today I noticed something going on the road, while listening to the music, the treble sounds both of them, but the voice of the soloist, the man's voice comes only from the right speaker. the problem disappears when it is inserted, but it does not stay in place. What do you think?
08.05.2020 20:33 # 2
onlycihan
4 years ago, I made aux to my Megane 2 vehicle, I applied the ones who did it before and applied the same sample as you. If the end of your cable has a socket, you change the positions of the pins entering this socket and you will catch the most accurate sound with the trial method. the onlycih 2017-09-09 21:56:30
08.05.2020 20:33 # 3
Alicilik
Can you take a photo of the cables?
0537 380 32 86 Included in the back of the tape
08.05.2020 20:33 # 4
Furkan979
Friends solved the problem on the ipod settings in the settings to the right and left, there is no sound, I pull it a little bit, that setting is equal to two, now it is enough. Thank you very much for your help.
08.05.2020 20:33 # 5
keqir
Either I have aux in my car, it keeps playing radio in the background when you connect mp3 player. Do you have such a problem?
08.05.2020 20:33 # 6
onurrr41
Does the Aux plug play CD changer? How do we activate this?
08.05.2020 20:33 # 7
Furkan979
I have no problem so I have a question, when I press it, I need input 1
08.05.2020 20:33 # 8
keqir
I do not have such a statement, the source key only changes between cd-radio. CD plays in the background while CD, otherwise radio plays.
08.05.2020 20:33 # 9
Furkan979
Is your tape rd4 or is it from old radios
08.05.2020 20:33 # 10
keqir
I think rd-4, the picture below,
when this is the case, I got it from the tape shown below, I got it all, bluetoth, usb, sd are all but still I want to play from the original tape frankly
08.05.2020 20:33 # 11
Furkan979
Now you have connected the aux cable, twenty three cables are already on the left and right left bidet electric. how did you connect
08.05.2020 20:33 # 12
Furkan979
I saw it on youtube, open the inside of the radio and solder it, if you did so, it could be because of it, I took the cable directly and plugged it back to the socket.
08.05.2020 20:33 # 13
ggitaristt
[QUOTE = Furkan979] I saw it on Youtube, open the inside of the radio and solder it. If you did so, it could be because I took the direct cable and plugged it back to the socket left left back [/ QUOTE]
I think you can measure a little with the cable gauge. If you have made a little resistance or if you couldn't fit the back socket, one of the sounds may be less. Come on, you can adjust the left and right volume on the iPod. Big smile
08.05.2020 20:33 # 14
keqir
when I got my cable it was plugged in and as far as I can see it was plugged in from the back. As you probably said, you need to activate it in the service. How many do they do this operation?
08.05.2020 20:33 # 15
ggitaristt
[QUOTE = keqir] was plugged when I bought the cable and as far as I can see it was plugged from behind. As you probably said, you need to activate it in the service. How much do they do this operation? [/ QUOTE]
20 50 100TL I do not know how much, it will be at the mercy of the man, just connect the computer and press a few keys.
08.05.2020 20:33 # 16
Furkan979
For now, there is no need, only in some songs, the vocal sound does not come at all, it sounds when it is either left or right, I do not want to get any of it.
08.05.2020 20:33 # 17
ggitaristt
[QUOTE = Furkan979] There is no need for now, only in some songs the vocal sound does not come at all. [/ QUOTE]
The common of the 3 cables of your aux cable is defective.
08.05.2020 20:33 # 18
maximusti
When I disassembled my original confirmation and connected the aux cable, it only gave treble to one side of the speakers. I think it's a similar problem.
08.05.2020 20:33 # 19
Furkan979
The problem is exactly the reason, I am telling you how it is right and left and there is electricity. I have no time or enthusiasm for this, I say thank God
