aux link help
08.05.2020 14:02 # 1
karsiyakaliozi
hello I made connection of ipod from aux in my 207 vehicle, but the sound comes out very little and bass sounds almost do not give any thanks.
08.05.2020 14:02 # 2
MirakGTI
Play with the equalizer settings of your iPod .. There is no LOUDNESS on / off option of the tape. Try it from there.
08.05.2020 14:02 # 3
karsiyakaliozi
[QUOTE = Mirak] Play with your ipod's equalizer settings. It didn't have a LOUDNESS on / off option. Try it from there. [/ QUOTE]
dude I did 2 operations loud loud but it affects very much but the sound is very low because i can get the sound i get on the radio normally at the level of 5-6 when i pass aux in 20-22 level thank you
08.05.2020 14:02 # 4
MirakGTI
There is already a little hoarseness in the aux, such an old cassette player would sound the sound will be cut thin, a sound called tısss.
08.05.2020 14:02 # 5
karsiyakaliozi
[QUOTE = Mirak] There is already a little hoarseness in the aux, it would be in the old cassette players.
I don't have anything like it. Sound quality is good, clean sound. There is another problem. There are 2 aux outputs in our devices.
08.05.2020 14:02 # 6
hasimayaz
[QUOTE = karsiyakaliozi] [QUOTE = Mirak] There is already a little hoarseness in the aux, it would be in the old cassette players.
One of the aux outputs is for the phone kit and the other is for the preamp. It mixes the sound of one source and unit and gives only the sound of the source. Do you get the same result on both aux inputs? You can also try with another mp3 player
08.05.2020 14:02 # 7
karsiyakaliozi
[QUOTE = hasimayaz] [QUOTE = karsiyakaliozi] [QUOTE = Mirak] There is already a little hoarseness in the aux, such old cassette players would sound the sound will be cut off.
When I tried aux 2 in service before, I tried to mix the source and unite sound as you said. what I understand from what you wrote is that aux2 is correct
08.05.2020 14:02 # 8
hasimayaz
[QUOTE = Karsiyakaliosis] [QUOTE = hasimayaz] [QUOTE = Karsiyakaliosis] [QUOTE = Mirak] There is already a little hoarseness in the aux, it would be in old cassette players.
The sockets are unlikely to be confused because you cannot plug the Universal socket upside down or wrong. Locked sockets can only be plugged. Is there a cd changer in the vehicle?
08.05.2020 14:02 # 9
karsiyakaliozi
[QUOTE = hasimayaz] [QUOTE = karsiyakaliozi] [QUOTE = hasimayaz] [QUOTE = karsiyakaliozi] [QUOTE = Mirak] there is already a little hoarseness in the aux, it would be in the old cassette players.
yes car has 5 li chancer also parrot ck3100 wire continent
08.05.2020 14:02 # 10
hasimayaz
The normal aux socket and changer line in are the same. changer may be giving a dip sound. if possible, remove the unit and remove the changer socket
08.05.2020 14:02 # 11
karsiyakaliozi
I have read things like some of the other strings in the interconnecting socket so we can fix the socket that goes to aux1 to aux2, so I guess it was more accurate to ask the socket interference.
08.05.2020 14:02 # 12
karsiyakaliozi
[QUOTE = hasimayaz] normal aux socket and changer line s are the same. changer may be giving a dip sound. if possible, remove the unit and remove the changer socket [/ QUOTE]
You're replacing me replacing with the chancer socket
08.05.2020 14:02 # 13
karsiyakaliozi
And the main problem is that I can get a little bit of sound when the sound of the ipod sounds too low, but I can get some sound by activating the bass settings loudly.
08.05.2020 14:02 # 14
hasimayaz
The unit in the vehicle isn't RD4 ?? And the aux socket you use is the aux socket that comes with the original vehicle. It's not a socket you bought later on ??
hasimayaz 2009-04-30 16:59:44
08.05.2020 14:02 # 15
karsiyakaliozi
[QUOTE = hasimayaz] The unit in the vehicle isn't RD4 ?? And the aux socket you use is the aux socket that comes with the original vehicle. It's not a socket you bought later on ??
yes rd4 and connect to aux output in torpedo ipod u
08.05.2020 14:02 # 16
hasimayaz
There should be a total of 3 sockets on the back of the unit. First Base socket, 2nd Aux socket, 3rd changer socket. The shapes of the changer and aux sockets are the same. But due to their locks, they do not sit in each other's nest. The 2nd socket has Aux1 right, left and GND - Aux2 right left and GND. Under normal conditions, when the aux sockets are turned on from the computer, only the source sound is heard on the Aux1 input. A third aux input is located in the cd changer socket. There can be no other option. Any socket cannot be installed incorrectly by normal means.
If your vehicle is out of warranty, you can measure the sound quality by plugging the ipod into your changer socket with the help of an electronic probe. of course, by pause the CD.
You can also try audio output by making the ipod cable mono. that is, by combining Left and right. I think the problem still comes from the source you have ??
08.05.2020 14:02 # 17
karsiyakaliozi
[QUOTE = hasimayaz]
first of all thank you for taking the time and writing an answer
there is no problem in the source, I can connect my n95 wire to the point and get the same low sound when I open the music, and this is just me, so I have read many problems in peugeot and abroad, this kind of problem is only in ingilize 5 I read that they fix the problem by changing the location of the min sockets so how can I assemble it because the aux output is rca uc?
08.05.2020 14:02 # 18
hasimayaz
you can replace it with the intermediate cable in your hand, not the sockets. You should combine gnd and left right + without short circuits.
08.05.2020 14:02 # 19
karsiyakaliozi
You can replace the [QUOTE = hasimayaz] sockets, not the sockets, by the intermediate cable you have. You should combine gnd and left right + without short circuits. [/ QUOTE]
the cable ipod side i use is 3.5mm headphone jack aux input rca uc shaped red white how do i say
08.05.2020 14:02 # 20
hasimayaz
Get an extra cable. Combine gnds into one + s one. Insulate with electrical tape.
Page : / 2
