AUTOMOBILE FRONT ORDER ANGLES
08.05.2020 14:00 # 1
The position of the front wheels that are controlled largely affects the movement of the vehicle. In order to give the wheels as smooth a movement as possible, they are made in an inclined state, not parallel to each other, but in different wheel planes. Wheel position is important in terms of steering safety and reduction of tire wear.
WHAT IS THE PRE-ORDER ANGLES?
The angle of the toe is the difference between the front and the back of the wheels when viewed from the top in the direction of movement.
The camber angle is lighter (negative) or closed (positive) than the upper part of the lower part of the wheels that touch the ground, this load reduces the load of the wheel nut, and thanks to the small rolling radius, less steering torque is required.
The axle pin (king pin) angle is the slope of the axle pin relative to the vertical, which is less steering torque
The caster angle is the angle made by the axle with the vertical axis of the wheel. It is made to prevent the wheels from climbing.
Regulating front layout angles is called rot adjustment for short.
The balance adjustment is the unbalanced load distribution of the wheel with respect to the vertical or horizontal axis. If we give the rotary and balance adjustment in the same definition now; The rot adjustment is made so that both wheels traction on the same axis and direction, and the balance adjustment is made so that the center of gravity of the wheels complies with this setting and does not wear the wheels unevenly. otherwise, the problems caused by vibrations on the steering wheel at high speeds or the inability of the wheels to grasp the road well are very important. It can also pull in both directions while it appears. overloading, hard and fast penetration into the pits, etc. situations may cause rot balance to deteriorate.
08.05.2020 14:00 # 2
sinan-s
Thanks for sharing ..
08.05.2020 14:00 # 3
kann87
thank you for sharing how much do you work emrah: DD
08.05.2020 14:00 # 4
MirakGTI
If the front is lowered too much, the front team needs to change every month.
