Automatic window adjustment is broken ...
28.09.2020 01:57 # 1
407 ERHAN
Friends, when the parking lights of my vehicle were on, I finished the battery, I started the battery from another vehicle by boosting the battery, but the automatic windows were out of order because the battery was completely discharged, they turn on and off gradually, that is, they do not open and close at once when the button is pressed, how can I fix this, thanks ...
28.09.2020 21:05 # 2
407 ERHAN
Friends, as I said, when the battery is completely discharged, the vehicle has reset the trip computer and all the settings of my vehicle are restored to factory settings, for example the windows do not open and close in one go, they open and close gradually, how can I restore it to its normal state, if we have a friend who has knowledge, he is very pleased if he can help. I would, thank you very much ...
29.09.2020 00:21 # 3
talip206
I think calibration is required. First, we turn on the ignition halfway, the battery lamp will be on. Then we will lower the window to the end and keep the button pressed down for 5 seconds, as if we want to lower the window, even though the window is open. Then, we will pull the button up, close the glass to the end, pull the button upwards as if it were open to the closed glass and wait for 5 seconds and the calibration process will be completed. Do the same for all glasses.
30.09.2020 10:52 # 4
whisky
When the battery is sufficiently charged, it automatically corrects the glass lowering and lifting process itself. When the vehicle walked and recharged the battery, it improved. calibration is as the aspiring brain wrote.
15.09.2021 21:18 # 5
407 ERHAN
Thank you very much, thank you, good luck guys...
16.09.2021 12:58 # 6
oguz_bursa
This also happens during battery disconnection. It gets better after about 4-6 km.
