automatic transmission problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:07 # 1
Fatihdumlu
Hello friends, my 2004 model 406 sv vehicle broke my transmission about two months ago, I made 3500 TL a month later, it was troubled again, the torque converter was scattered, they did it again, then the oil temperature of my car does not go to the gears until it reaches 80-90 degrees. It falls into rolent, but when I go to the gear, I will get my feet out of the gas and it will go back in its normal age.
08.05.2020 20:07 # 2
pepecura
did you hurt and chewed? did you see?
08.05.2020 20:07 # 3
As far as I understand, if you remove your foot from the gas, the vehicle continues to deliver gas continuously.
08.05.2020 20:07 # 4
Fatihdumlu
I haven't seen the brain cleared
08.05.2020 20:07 # 5
Fatihdumlu
When I pull my foot out of the gas, the vehicle falls idle, until the gearbox oil reaches 90 degrees.
08.05.2020 20:07 # 6
Fatihdumlu
There is no problem after the oil temperature reaches 90 degrees and the gear changes are going on at the normal speed when I pull my feet out of the gas.
08.05.2020 20:07 # 7
KILIC
wow buddy, when these gearboxes get hotter, you don't work efficiently. There may be a brain problem
08.05.2020 20:07 # 8
Fatihdumlu
Today I left the car to the master, he will stay there in the evening
08.05.2020 20:07 # 9
Fatihdumlu
Friends in Ankara Are there any masters you can recommend a good master in these transmissions in terms of both engine and transmission
08.05.2020 20:07 # 10
talip206
They say the solution auto transmission is good. Write out the address on the Internet. Many people praise, but I have never been.
08.05.2020 20:07 # 11
Fatihdumlu
Ok thank you thanks
08.05.2020 20:07 # 12
Suleyman0642
I bought my friends 406 automatic cars, while on the road, traction has fallen, and now it is not moving even when in gear, my car is shifting, it eats gas, but it does not go. Can you help me?
08.05.2020 20:07 # 13
[QUOTE = Suleyman0642] Friends, I bought 406 automatic cars, while on the road, traction has dropped, and now it does not move even when in gear, my car is shifting, it eats gas, but it does not go, why would you help me?
First of all, welcome to us. good vehicle. My teacher is most likely caused by solenoid valves, costs between 600-800 TL. worst case may ask for shaman revision. It will cost between 3000-4000 TL.
sonerkyl 2017-04-10 08:53:14
08.05.2020 20:07 # 14
Djeati
[QUOTE = Fatihdumlu] Friends Are there any masters in Ankara that you can recommend a good master for these transmissions in both engine and transmission [/ QUOTE]
a bit old but was infallible in matters aygoğ ankarada transmission ankararn the best I can say is it is a bit salty guaranteed the job done
the Djeat 2017-04-13 15:45:13
