AUTOMATIC TRANSMISSION OIL HELP ??
Homepage » PEUGEOT MODIFIED PLATFORM » Virtual Modified
08.05.2020 19:05 # 1
10URAKAR
Hello friends,
My car 206 automatic gear ... In the morning, when the car starts without warming up, the gearbox protects itself (ie * and S mode flashes). I think it is from oil, I saw the last oil of opet. Is this oil used?
How much can I get this job done.
I am waiting for your help on this subject
have a nice day,
Tongue
08.05.2020 19:05 # 2
OkanTekin
If you think it is caused by transmission oil, it's not very easy to change it. In the simplest way, you should find a channel so that you can get under the vehicle.
My advice to you Firstly find out how many km of gearbox oil is with OBD device. If necessary, you can add. You can also buy a product of 13-15 pounds, I do not know its quality, but the product you bought will cause you to pay more in the future. I think the right thing to do here is to use the gearbox oil recommended by Peugeot.
Whatever the price. There is avoiding giving 100 lira and causing 2-3 thousand lira damage. It may even cause you to have an accident while you are on the road. Nothing matters to human health ...
If there is another problem other than oil, there is a piece called solenoid valve that comes to my mind first. This may have malfunctioned. Repairing can be a bit costly ...
Or, there is a small part that mechanically controls other gear changes as the automatic gear shifts from P to other positions (when you press the brake). I couldn't remember his name right now. He may have lost his function. This is a cheap piece by the way ...
These are the things that come to my mind.
08.05.2020 19:05 # 3
10URAKAR
Okan Bey,
Thank you so much.
I wish you good work,
08.05.2020 19:05 # 4
hasanhasan
Hodja, if you haven't bought oil, you can buy it here.
http://urun.n11.com/hidrolik-sistem-yagi/hidrolik-direksiyon-yagi-atf-p57282667
