automatic transmission oil and its problem
08.05.2020 16:52 # 1
volkan22
my friends are good forums.
my vehicle & nbsp; 306 automatic transmission has BLA Al4 & nbsp; it gets hit in gear nights, sometimes I can't drive the vehicle in D position and the sports lights are blinking, the vehicle is dropping from the drive. I pull it off and it runs and when I run it (it does not make this malfunction on the right track, it turns out that the sports and snow lights are flashing)) I want to check the oil. I have not seen anything similar, I would be glad if you help me, at least if I am sure that the oil will not cause serious malfunctions.
volkan22 2012-06-26 01:51:10
08.05.2020 16:52 # 2
metin
Hello. & Nbsp;
These transmissions do not have a dipstick, they only have a plug to fill. & Nbsp;
Normally this oil It needs to be replaced with a Mobil LT 71141 oil at 30,000 km, if it has not changed before, it should change as soon as possible.
08.05.2020 16:52 # 3
toga406
Don't worry, I have this problem too, it has nothing to do with oil
I think the oil caused by the cooling device gets hot when it gets too tight, even in the city, stop it, even in the city. >
I'm still riding so
08.05.2020 16:52 # 4
fTh206
If the snow and sports mode lights are blinking, I think you can connect and look at the defective computer in the solenoids
08.05.2020 16:52 # 5
[QUOTE = toga406] never worry, I have this problem too, it has nothing to do with the oil
I think the oil from the cooling device gets hot when it gets too tight, even stop and go in the city
solution
I couldn't find it either.
I'm still riding so
Don't keep every problem with yours. There are thousands of problems and most of them emerge in this way.
08.05.2020 16:52 # 6
toga406
[QUOTE = koliva] [QUOTE = toga406] don't worry, I have this problem too, it has nothing to do with the oil
is it a solution
I couldn't find it too
I'm still riding so
Don't keep every problem with your own. There are a thousand rounds of problems and most of them emerge in this way.
snow and sports are generally a mistake reflected in the gearbox
I'm not a master who has not visited
They said there are many factors showing the error to the gearbox
couldn't say what happened
By the way, 307 and al4 in the meantime have changed the solenoids that had the same problem but still had a problem with an unsolved problem
KOLIVA. yes, you can become a manager
you may have a lot of knowledge
but they say they know a lot, they are very wrong. I don't know, will you join?
I can't give solenoid right away
but first everyone says oil did not change solenoid.
I didn't say the same.
I think there is a problem with the cooling system of these vehicles, I say for al4
I will be saved if I sell it. but if I could solve it, I would gladly use it at low cost.
08.05.2020 16:52 # 7
[QUOTE = toga406] snow and sports did not say that there were a lot of factors that showed the error to the gearbox that I did not have a mistake that reflected on the gearbox in general. yes, you can be a manager, you know, your knowledge may be too much, I do not know if you agree, I can not give the solenoid immediately, but first everyone did not change the oil says solenoid. I did not say the same. In my opinion, these vehicles have a problem with the cooling system. but if I could solve it, I would gladly use it at low cost [/ QUOTE] Estagfirullah I have no such purpose. I don't claim to know much. I just share my information. I have been wrong many times. It was obvious that I could not understand where it came from. Also, management does not have anything to do with it. I was trying to help in the same way when I was a normal member. I do not remember that I recommended solenoid replacement for your problem. In fact, I even said that there was no problem in your vehicle for transmission. I have written very nice things in your last message for your problem. Did you check or have the parts that I stated under the light of this comment? -25 22:31:08
08.05.2020 16:52 # 8
toga406
I didn't apologize, in fact, I apologize for you anyway because you are the one who helps everyone by writing comments.
I will not crash for you
thanks for your tolerance
stay with you
08.05.2020 16:52 # 9
rugger35
What kind of a beautiful place is the world when people are tolerant? & Nbsp; "Smile"
08.05.2020 16:52 # 10
volkan22
Thanks for helping my friends, thanks, as you say, auto transmission makes a thousand-round malfunctions.) But as I mentioned in my article, I do not drive in the D position as I mentioned in my article, it makes me feel uncomfortable. sports lights come on and shifted when gear shifted 3 and shifted when it started ..
also attracted my attention. , 5 // then it turns into 2 gear, & nbsp; my vehicle is 119 thousand km & nbsp;
& nbsp;
let me tell you about the temperature in case the temperature does not exceed 90 If you ask & nbsp; the gear does not change the gears, it seems as if it does not fall when it goes to 3 while it is coming down, it does not fall, and it seems as if there is a drowning, & nbsp; When falling into 2 gear, the same wurunt always comes up to the same wrinkle when it comes to the same wrinkle, and always makes a serious wurunt at the same point ... div> volkan22 2012-06-26 00:49:53
08.05.2020 16:52 # 11
monur
Guys, first, let's agree on this. Let's not approach the question of the problem with automatic transmission as oil and cellophane directly. The symptoms of both are different. The company Peugeot says; The oil I put in this gearbox is 150 to 200 thousand km until the gearbox revision, this value does not need to be changed. (Unless otherwise stated) The risk of wear and deterioration of this oil is much too late compared to normal mineral oils. The reason is that it is in a completely closed system. The only thing that can spoil the oil is the lining of the lining, which requires gearbox revision and is at least 150 thousand km under normal use conditions. The hydraulic unit and torque go all the way to the converter. The figures such as 3000 and 5000 mentioned by the masters are only for the transmissions that are locked and cannot be walked. I think it should open the gearbox without any more force. Snow and sports mode lights only detect electronic malfunctions on the gearbox, do not detect mechanical ones. Also, I agree with Tolga, cooling systems are not enough for these vehicles. Anyway, you will get out of your pocket comfortably and comfortably. However, I think AL4 transmissions disrupt the DSG gearbox when it is used as it should be used. While AL4 adjusts the shift times according to the driving situation of the driver, the other vehicle I use is shifting from the start up to 8 gears in a row. Those who use it know that this gear structure is going at a speed of 100 km. (It takes some time to get used to) AL4, while descending a hill, takes down a gear and takes the engine to the compressor and provides a safe landing, as long as the slope is steep, even if the tachometer is redline, unless you touch the throttle. The question of your friend has boiled in between, can you write the km of the vehicle and let us guess accordingly.
08.05.2020 16:52 # 12
volkan22
I wrote on a top topic, bro, the car is already going to be a problem. & Nbsp; While driving in the D position, the gear knocks at the shifts and & nbsp; when the long slope strikes, the sports and snow lights flash 3. The gear shifts out of it, and the car goes out of its way: SS
the pull of the vehicle is very nice and the & nbsp; (D) position also does not flow backwards, but when you put it in (D), the sound comes from the transmission. I don't understand the sound of the pump.
and in a significant part (1 gear --- 2, as if 1-half - then 2 gears, 3 gears like 2 (2 until gear)
why am I afraid that our understanding engineers who do not understand here will offer me a thousand things to cut money like that, the most expensive way will be like sanziman, etc .. so help & nbsp; help lazim lutfen.
volkan22 2012-06-26 01:59:54
08.05.2020 16:52 # 13
ismail ozdemir
friends always say this oil change just fantasy does not work so much do not play with your wasted transmission ...
08.05.2020 16:52 # 14
toga406
The feeling of shifting to 2.5 gear after the second gear was at that moment that it was due to the pressure relief,
was also saying that there was also the BMW
was actually in 2 gear but it was making sense to release the pressure to the 3rd gear and it made sense
I wondered about me and learned about it when I researched it.
& nbsp;
08.05.2020 16:52 # 15
toga406
Well, METİN master.
I have the same problem in my vehicle. 2003 406 hdi bva at 143000
doing it when the oil is heated
what can be the solution?
by changing the thermostat If we let the fan sensor turn on not at 90, but at 80 before, the problem will be solved a little.
& nbsp;
08.05.2020 16:52 # 16
caspercenk
Hello guys, is this
transmission cooler? Just below 306 batteries.
my heater core changed, I noticed at that time. I saw the same as a diesel diesel cooler.
08.05.2020 16:52 # 17
[QUOTE = caspercenk] hello guys, is this
my heater core changed, I noticed at that time. I saw the same as a common diesel transmission cooler. nofollow "> http://s328.photobucket.com/user/caspercenk/media/WP_20160313_001_zpst6p4trq5.jpg.html
Yes refrigerant is the part in the picture. By the way, you had a good subject. You brought me back too & nbsp; "LOL"
08.05.2020 16:52 # 18
serkanay55
Everybody who wrote the problem did not write that they could solve the problem, or we got their vehicles, but we just got it & nbsp; & nbsp; & nbsp; I have such a problem but it just knocks in the hot weather normally I don't have any trouble in the transitions, I am sure I will write it if I find a solution now 😂 € 514;
08.05.2020 16:52 # 19
alikonce
the subject was good, it was good when it got hot in traffic for a long time just because it was hit at the reason of the cooler reason ???
08.05.2020 16:52 # 20
serkanay55
Transmission masters will say that solenoid and oil will dissolve immediately, but I will not take care of many masters first, if not, I will find a way to do a hand prisoner.
Page : / 2
