automatic transmission malfunction
08.05.2020 14:17 # 1
ramtas
Hello friends, I have a 2005 model automatic gasoline 307 pejo. My car has been doing 90-95 at 30 revolutions for 10-15 days. I changed the oil last week and connected it to the computer, the oil has lost 50% feature.This also changed the solenoids 6 months ago.
08.05.2020 14:17 # 2
ErolSen
I read it 3 times, I didn't understand anything.
08.05.2020 14:17 # 3
Onur
4th gear 3000 rpm 110 km speed normal already I don't understand what is abnormal here
08.05.2020 14:17 # 4
ramtas
yeah right. i'm getting a vehicle rocket then it gets better
08.05.2020 14:17 # 5
ramtas
Abnormally doing 95 in 4th gear at 30 revolutions
08.05.2020 14:17 # 6
Onur
When it does not make gas from 3 to 4 dips, it doesn't throw it away
08.05.2020 14:17 # 7
ramtas
If I do not make rocketing, if I go rocketing with 95 km, I will go at 110 km, if I stop at 4, it will still be the same as before.
08.05.2020 14:17 # 8
ramtas
I look at the negativity of the triptonic vehicle four. but as if he is going on a gear between 4 and 3.
08.05.2020 14:17 # 9
Onur
then I would like to have the solenoids of the 3rd and 4th gears checked, but it didn't come
08.05.2020 14:17 # 10
ramtas
I showed it to the 3 masters, each of them says differently, someone does not close the solenoid completely, someone says it is 6 months since the filter revision diode has been in debt.
08.05.2020 14:17 # 11
Onur
I do not think that it will be a revision, as if the master made a little bit of 3-4 gears as if he was blowing for another 6 months, I think there is a problem in 3-4 solenoids.
08.05.2020 14:17 # 12
ramtas
the first master said to me that he sent me a part of the oil into the 3rd gear, he did not send the 4th gear to full gear. The fault code did not fall in his work. It was formed in this way in the middle gears. By running both gears at the same time.
08.05.2020 14:17 # 13
ErolSen
I think there is no abnormal situation in me, for example, in light ramp locations, shouting at high speed in 3rd gear without making a 4 or 4 throttle. but when you set off on the same road at the same gas setting, it throws 4. This happens especially when the vehicle is full.
08.05.2020 14:17 # 14
ramtas
But my car is doing in 4th gear, I'm looking at triptonics, a quarter. Also when driving on straight road, the 4th gear makes 95 km at 30 speeds, and suddenly it drops to 25 at a speed as if the gear is shifting.
08.05.2020 14:17 # 15
BAHTIYAR
my car 307 auto, I heard a lot of malfunctions, I started to be afraid of the forum, I paid a lot for the car to be in the car for a long time (prins lpg, heavy maintenance, tire) 68 thousand but I started to be afraid my car is easy to gear, I do not know about it
08.05.2020 14:17 # 16
ACHTUNG
[QUOTE = ramtas] 95 in 4th gear at 30 revolutions that are abnormal [/ QUOTE]
There is no abnormal situation, I use 307 otm. The car is doing this speed with the long gear of 3 gears.
I think you press a little bit of gas, it is perceived according to this, it is not a problem.
08.05.2020 14:17 # 17
ramtas
The negative vehicle is already doing 95 in 4th gear, and if I give less gas at 30 cycles, 95 vehicles in 30 cycles are going as if in 3rd gear. then something happens, suddenly, the vehicle is falling, sometimes whatever I do is going to go with 95. For example, I came to Istanbul yesterday from manisa to Balıkes. in gear and straight track
08.05.2020 14:17 # 18
ramtas
friends, I have been riding this car for six months, it is my first car. tachometer rushes, then something happens, it gets better as before.
08.05.2020 14:17 # 19
ramtas
my friend mitto has experienced the same fault as I could not reach him, I did not enter the site, he did not reply, he did not reply, the same as my fault, on the second page in the faults section written a month ago
08.05.2020 14:17 # 20
There was a piece replacing the press pad for tiptronics. You know, if you press the gas manually, the speed rises, but the car does not go. Should this not be the beginning of this event? It was striking in other parts of me, and in tiptronics, there was a piece that replaces the pressure pad and it is the same when it scraps. hakangumus 2010-06-30 16:45:05
Page : / 2
