Automatic transmission knocked down
08.05.2020 15:57 # 1
onlyyou42
My friends 307 xt premium automatic gearshift sometimes knocks on first departures in congested traffic.
It almost sticks me to the seat, if it is correct. AğlamaAğlamaAğlamaAğlamaAğlamaAğlama
08.05.2020 15:57 # 2
metin
yahu, you both ask for help, but you do not do your duties.
First of all, there is as much information about this in the forum as you would like, even the same problem I got over.
First you need to open a self-introducing subject, if you have opened it, you should share your city and district information in your profile.
08.05.2020 15:57 # 3
vbmaster
I'll give you a link but don't forget to introduce yourself :)
http://forum.peugeotturkey.com/forum_posts.asp?tıd=16819&kw=otomatik+%feanz&pıd=261756&title=ara-stop-etmeye-balad#261756
08.05.2020 15:57 # 4
metin
[QUOTE = vbmaster] Let me give you a link but don't forget to introduce yourself :)
I don't think this link will have something to do with a subject. The classic malfunction of these AL4 automatic transmissions Göz Kırpma
08.05.2020 15:57 # 5
metin
Alper brother do not make trouble first, we will take your car to the service, you are lucky that there is no LPG because they do not get into service when you have LPG.
I want you to do a little test before I go to the service. about (10 degrees) on a slight slope. Put the vehicle in "D" mode and take your foot off the brake. If the vehicle is not running back then there is no big problem.
Then take the vehicle to the service, only increase this temperature when the hitting is high when the temperature is high, then connect the vehicle to the computer (get it working) when it connects to the computer, if the temperature is high and the transmission oil pressure is below 2.5 bar while operating the role "solenoid valve" also known as " Replace the electro valves will be no problem.
As the original electro valves are troubled, the oil pressure drops when the gearbox heats up and it changes the gears by knocking because it cannot produce pressure.
08.05.2020 15:57 # 6
onlyyou42
Brother my gears do not change, knocking. Almost like oil. Just knocking on the first departures. I took the lady and the child. The temperature resistance was always working at low speed. The temperature was always above 96 degrees Celsius. I caught my attention to the electrician. I went to the electrician. I did not use peugeot before. I was ill. My daughter is 9 years old, dad says don't sell this Star .But this boredom bored me, my sleep is running away. Mubarak is day. I can not even swear mouthful.
08.05.2020 15:57 # 7
vbmaster
Either it has nothing to do with it :) I had a quick look at the night time. Sorry ...
08.05.2020 15:58 # 8
metin
Listen to me, look at the transmission oil pressure. He replaces the gears with pressure and puts it on the gear with oil pressure. When the vehicle is in gear, the gearbox oil pressure rises and shifts when the required pressure is not present, but when it is in the throttle, the gear shifts into gear, and the progression occurs as if they hit the back.
Measure the transmission oil pressure when the vehicle is at the authorized service, I think the old type of solenoids so replace it
08.05.2020 15:58 # 9
onlyyou42
It is true how average these valves are. Also, if there is a problem with the valves, does the anti-skid and sports driving mode lamps not lit continuously?
08.05.2020 15:58 # 10
metin
It doesn't burn, I know it happened to me. neither malfunction nor light. hitting is very hard but there is not even a fault record. eventually we understood the low transmission oil pressure. When the engine and transmission are cold, there is no problem, but when a certain temperature exceeds.
For example, I lived so much in spring that I said that if it was the first spring, what would you do in summer. Well, I changed the solenoids on May 19, and since then it hasn't done it even in the busiest traffic.
Solenoids, two of which are 180 TL if I am not mistaken. Together with the solenoid, they change the oil and introduce the new type of solenoid to the brain.
If you change it, you should pay attention to the level of fat put in and the introduction of solenoids into the brain.
08.05.2020 15:58 # 11
onlyyou42
The car does not always do this job. I just went to the service. The master took and drove it. There is no work. The masters (the masters of my stroller) say let's get off immediately.They said they went down to the seroneoid change + oil change, they said it cost 900 TL. Isn't there a master in the world like a man ??????
08.05.2020 15:58 # 12
onlyyou42
I did the stop-and-go test on the ramp. There is no problem. But the master started by the lightweight kidnapper.
08.05.2020 15:58 # 13
berk2309
Do not faint in the 2nd gear in the car and a sound will sound like a flick
08.05.2020 15:58 # 14
onlyyou42
No, brother, only when he's shifting from 3rd gear to 4, he sometimes sees 3500 cycles that much
08.05.2020 15:58 # 15
berk2309
After your complaint disappeared, from 1 to 2, it knocked on it as a blunt. I guess I was doing it when I was cold.
08.05.2020 15:58 # 16
onlyyou42
No, he does it while getting up. No problem afterwards.
08.05.2020 15:58 # 17
metin
[QUOTE = onlyyou42] The car does not always do this job. I just went to the service. The master took it. There was no job. They did the same as yours. The masters (masters of my hat) say let's get off immediately.They said the change of the seroneoid + landed on the oil change cost 900 TL. It would cost 3000 TL. Isn't there a master in the world like a man ?????? Pain in my head got nervous. [/ QUOTE]
Do not be afraid if they do not miss on the ramp, they said 2500 to me, they stopped, I did not handle, I researched and finished 491 TL. solenoid change oil change software vs 500-600 amount 900 shook a lot. if you change it at an authorized service center. special services cannot assign software to introduce the new soleonid. Also, since the authorized service replaces the solenoid guaranteed, you will not have to pay the same apra if the same problem occurs.
08.05.2020 15:58 # 18
metin
[QUOTE = onlyyou42] I did a stop-and-go test on the ramp. [/ QUOTE]
How lightly the pads are missing? You should have done 180 to 200 thousand km for the pads to be missed.
08.05.2020 15:58 # 19
metin
[QUOTE = onlyyou42] No brother, just switching from 3rd gear to 4, sometimes he sees 3500 cycles so much [/ QUOTE]
I have just learned that the shift gears are more likely to be abnormal in the transmission from the brake sensor. or rather, the transmission was working abnormally even though the solenoids were changed.
There is a simple way to tell if the brake sensor is faulty. When you start the car, you need to press the brake to take it out of park mode or it will not come off. Have you ever unlocked the lock even though you pressed the brake? if it is defective. 20 tl or something. test it, change it.
08.05.2020 15:58 # 20
onlyyou42
Sister vehicle is 133 thousand.
Page : / 5
