Automatic transmission gear shift failure
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
07.02.2025 18:48 # 1
Zeynepk
I bought a 2015 model 208 semi-automatic gasoline vehicle 1.5 months ago and after 1 week, when shifting to 5th gear, it was dropping to neutral for 3-4 seconds. After a while, 5th gear started not shifting at all or shifting momentarily and dropping back to 4th. A software update was performed on the vehicle, but it did not fix it. It was said that the transmission had gotten water, but it was cleaned, but the problem still did not fix it. The vehicle has been in the industrial areas for 1 month. Has anyone experienced this problem before or has any suggestions? Zeynepk2025-02-07 18:49:10
20.12.2025 12:39 # 2
Tuna2641
Hello. https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" I've experienced the same thing before. The display shows 5, and when I try to shift gears and can't, it drops to 4. The 5th gear hub bushing and synchronizer have been replaced. I also recommend having the gear shift fork checked. Its ends were quite worn.
