Automatic Transmission Fault code?
08.05.2020 15:56 # 1
naksi
No problem when my friends vehicle is cold (307 2004 model auto)
But when I get on the road, I get an automatic gear fould error when it gets close to 90 and * - next to the gear screen and a little later just the - sign remains, I continue to have to do it, then, after a while, the automatic gear comes back for 15-30 minutes.
I have it connected to the computer today
p0717 - input / turbine speed sensor "A" circuit no signal
What are these malfunctions?
Meanwhile, cellonoid valves and oil changed 2 months ago.
08.05.2020 15:56 # 2
metin
solenoids authorized service system special service system changed?
the brake is not okay, so sometimes when the gear is in the park, does the gear you need to remove from the park when you press the brake
08.05.2020 15:56 # 3
naksi
yes sometimes he did it today, for example, but i don't understand what this problem has to do brake brake can give this error?
08.05.2020 15:56 # 4
naksi
the solenoids may have changed the oil in the special service, the oil may have changed incorrectly die suphelenelim mobile 1 lt 17111 what they might not have used it die I'm afraid because it gave this error in the first very hot weather and it is constantly giving
08.05.2020 15:56 # 5
naksi
If you do not have any friends with any other ideas, the revision will be very salty :)
08.05.2020 15:56 # 6
metin
[QUOTE = naksi] yes he does it sometimes, for example, but I don't understand what this problem has to do brake brake can give this error? [/ QUOTE]
I did not know, I learned by chance. when there is malfunction in the brake sensor yours seems to be faulty, abnormal operation occurs in the transmission when the brake sensor is faulty
08.05.2020 15:56 # 7
metin
[QUOTE = naksi] solenoids may have changed in the special service, the oil may have been changed incorrectly.
You should change the solenoids at the authorized service, as soon as they change, they must introduce new types of solenoids to the vehicle before starting the vehicle, special services do not do this,
08.05.2020 15:56 # 8
berk2309
I am afraid that you have a problem in the medicine like me. I have faded twice before, but if you do this problem without making progress, make the flush sound in the 2nd gear finishes the pads. Pert was like zero from the vehicle. I did not see the repair of the turbocharger.
08.05.2020 15:56 # 9
zeynep taylan
How much does solenoid and oil change cost in special services?
08.05.2020 15:56 # 10
hcbank
solenoids 600 tl
oil change 100 TL prices in this transmission service ....
I write when I find out that I will go to the authorized service on Saturday
08.05.2020 15:56 # 11
berk2309
It serves 700 lira already that heat I made 630 like
