Automatic transmission does not crank
09.12.2020 10:23 # 1
arachnid
Hello dear friends; 206 2003 fully automatic vehicle does not start when I start. I brake with the gears of my vehicle and play as I want. It shows on the screen which gear is engaged, but still never presses. as if the car was in gear. I say position sensor but it shows where the gear is. brake switch dicem vehicle I can switch from park to neutral and gears. Is there anyone who can solve such a situation.
10.12.2020 08:49 # 2
Hello. Sir, do you have LPG in the vehicle?
10.12.2020 09:14 # 3
arachnid
Yes, master. Atiker. After opening the subject, I researched a little more. I found a video on Youtube, someone took a video about the same problem. The problem was the starter motor. I will go to the electrician in the evening.
10.12.2020 12:55 # 4
talip206
Most likely it is the starter motor. It says click when it's cold, as if it sticks. The second is also turning. It seems that it is time to overhaul the starter
22.12.2020 00:59 # 5
berkantyildiz
First, check your battery. If the problem is not in the battery, check the starter motor. probably the starter motor
25.12.2020 18:46 # 6
arachnid
My problem was resolved when the gear position sensor changed. Thanks a lot for the answers. transmission oil maintenance time had also come. I had it done. it's not about the electrical system.
25.01.2021 21:34 # 7
djserp
If the ignition lamps completely go out when you start the starter, your battery is dead, only if the battery lamp goes out, the coal or bushings of your starter are out.
