Automatic transmission automatically switches to manual
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
07.10.2020 13:38 # 1
Harme
Hello, my 2010 model 3008 automatic vehicle is on the move, or while driving, the automatic text on the screen goes. turns back to automatic after a while. He does not go up from third gear when he switches to manual. It probably protects itself and allows you not to go fast. Since there are not many articles on this subject on the internet, I got the following answers in my close circle: - The transmission oil is low. Therefore, if you change the oil, it will be fixed. - The switch inside the gearbox is broken. Better sell the car, too expensive. -Brain is broken. You will get a new one. -It is broken, it is damaged, it is very expensive, automatic so it is bad manual candir etc etc etc. People cannot go beyond breaking morale. Everyone in this country is hungry for everything and is full of information. Anyway, let's come to the conclusion: It is difficult to find reliable masters at this time. When you find it, you should not leave it. Like my master. He said he connected it to the device and saw the brake sensor failure. He changed it for 110 TL including labor and the problem was solved.
07.10.2020 18:16 # 2
As you said, I swear to you, it is easy to throw it away without looking at it completely. You have experienced what a simple part causes. You are especially right about the master.
08.10.2020 08:58 # 3
uzunca961
Get well done cheaply. I had the same problem in my 2010 308, but the problem was caused by my brain, I got a money like 1000 TL out of my pocket. If you tell your master, friends can benefit from it.
12.10.2020 12:43 # 4
Harme
Yiğit Automotive - Pendik on the e-5 in the direction of Ankara.
14.10.2020 15:13 # 5
k4diryilmazzz
I have it too 3008 I am very glad I did not have a problem
