Automatic Transmission and Abs
08.05.2020 21:18 # 1
kerim97
First of all hello to everyone in the Forum,
My car is a 2004 model peugeoet 307 SW 1.6 Pack automatic model.
There was a problem in our vehicle; Automatic GearBox Fault.
The transmission was repaired because it previously gave the same problem and solenoid valves, gear lining, gear oil etc. changed. For the last 2-3 weeks I have been getting the same error again in bend turns and slope climbs, and this day we took it to the gearbox, when it connected the vehicle to the computer it was observed that there was a Pressurization and ABS failure.
As a result of my research, the abs brain or abs sensor malfunction may affect the operation of the transmission, and it was caused by the abs problem in another person experiencing the same problem.
If my master is driving the car again today, if it is the same problem, it will be connected to the computer again tomorrow and the errors will be checked if it gives the same errors, the repair will be done accordingly. Do you think the problem may be caused by abs? have there been friends who have experienced this problem before?
and the vehicle seemed cumbersome, its traction dropped.
Best regards..
08.05.2020 21:18 # 2
can be my teacher sockets etc. clean and observe again. In automatic vehicles, the vehicle shifts, etc., are slit from many sensors. Abs fads are one of them. I say change the brake sensor and try it. It's not a very expensive piece. but have the abs sensor sockets cleaned and checked nicely. I say.
08.05.2020 21:18 # 3
kerim97
The last day we took it to look at it, it appeared as a pressurization failure, the solenoids will change again on the day of the Wednesday and the abs sensors will be cleaned, I will inform you again according to the situation.
08.05.2020 21:18 # 4
kerim97
The vehicle was repaired, only 1 solenoid valve had a problem, they changed it and the problem was fixed. How about 1 solenoid changed, do you need any gearbox software? The master said no need.
Best regards..
08.05.2020 21:18 # 5
Get well soon. There is no need for my teacher to do the necessary repairs before the repair is done before.
08.05.2020 21:18 # 6
Fatallius
Hello, where did you get my teacher and how much did it cost you?
