automatic transmission
08.05.2020 16:20 # 1
abc1979
Hello friends, I just joined you.
& nbsp;
2 weeks ago I bought 206 1,4 X-LINE, 2004 model is automatic. At 82000 km. When I make speed, sometimes I see the speed of 110 km at 3000 rpm, sometimes at 4000 rpm but I see the speed of 110 km, the car is shouting. Sometimes so sometimes so, can cause. I feel very comfortable at a speed of 110 km at 3000 rpm, I don't like the speed anyway, it is 110-120 max. But when I go up to 4000 cycles to go with 110, I have the feeling that the lungs of the car will be removed :) Thanks.
AlbaYDemircaN 2011-11-08 21:14:39
08.05.2020 16:20 # 2
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading of "Getting to Know Our Members". //forum.peugeotturkey.com/new_topic_form.asp?FID=221.- Your name, surname: 2.- Your age: 3.- Your vehicle (Brand, model): 4.- Your hobbies: 5.- Your profession: 6.- Site where did you hear: 7. Blood Group: 8. your horoscope: 9. Fan favorite team is: 10. Which county or İlda here: 11.- MSN address: Thank you for your interest ederiz.peugeot Turkey F & I Club Yönetimiwww.peugeotturkey.co I www.peugeotturkiye.co
08.05.2020 16:20 # 3
Ucyuzalti
110 to 3000 cycles?
110 to 4000 cycles? & nbsp; Reviews
08.05.2020 16:20 # 4
berk2309
The car has to be at 3000 revolutions while it is going to 110 and in this forum, we solved this with brake brake & nbsp; when your conviction breaks down, you can put the price of the pedal between 10 and 15 TL immediately on your pedal.
08.05.2020 16:20 # 5
AliOzagan
when I have 5 people in my vehicle, he sees it comfortably at 3000rpm
08.05.2020 16:20 # 6
it does this when the print starter is finished.
08.05.2020 16:20 # 7
emin15
When the vehicle is 110 km and 4000 rpm, it is stuck in the 3rd gear, then take your foot off the gas.
08.05.2020 16:20 # 8
abc1979
Thanks for the information you provided, friends, but I'm confused. I think I need some more comments :(
08.05.2020 16:20 # 9
berk2309
friend, there is no automatic lining in the vehicle, there is a band set in the vending machines.
08.05.2020 16:20 # 10
my friend, don't worry about your use :) When you go to me at 4 am, when the gas is overloaded, you switch to 3, then you can go until you get your feet out of the gas, try the brake sender as follows, start the car, take your foot off the brake, then press the brake again, if it sounds like click on the gearbox. It means that it is working, if the brake customer is not working, your car will remain stuck in the morning, we have fixed the experience, I know that I am alive. because I couldn't find it in Diyarbakır :) :)
08.05.2020 16:20 # 11
berk2309
brake sensor & nbsp; Not only does this work, but only my brother, the same time, the communication between the brain and the transmission is dry, and if there is a problem in his mind, I do not think that I am braking.
08.05.2020 16:20 # 12
[QUOTE = berk2309] brake sensor & nbsp; Not only does this work, but only my brother, the same time, the communication between the brain and the transmission is dry, and if there is a problem in his mind, I do not think that I am braking. [/ QUOTE]
interasan look, I never thought about this part :) When you look at it, is it not a different piece that looks like any other?
08.05.2020 16:20 # 13
berk2309
I was thinking about it, but unfortunately it was not, unfortunately, my father's friend who worked in the authorized service said that I thought he would take the gearbox. we shared what we know & nbsp; This summer I got the gearbox complete. It should be the price list in the original service.) & nbsp;
