automatic transmission
08.05.2020 16:36 # 1
YUNNES37
Greetings
With my automatic 2000 model peugeot 306, yesterday, when the hill climbed up, the snow and sports mode lamps started to light up and the vehicle's passing fainted.
I pulled to the right, I stopped, I ran, it improved. I wonder why.
What should I do to maintain this gearbox? There's no kidnapping back, but maintenance is necessary?
08.05.2020 16:36 # 2
fTh206
flashing of snow and sports mode shows that there was a malfunction warning had been with me 3 months ago you need to change the solenoids also neglecting damages the transmission, it costs a lot more
fTh206 2012-02- 21 11:05:10
08.05.2020 16:36 # 3
kuantum
the solenoid change seemed to you.
08.05.2020 16:36 # 4
YUNNES37
I understood what is required to go to the master & nbsp; what is the cost of this job in
08.05.2020 16:36 # 5
cetin
Mine is doing it too. Especially when climbing uphill; it does it in cold weather or when the engine is cold. When the engine is hot or when the weather is hot ... some friends say the same error occurs after the solenoids change. ..
08.05.2020 16:36 # 6
fTh206
[QUOTE = YUNNES37] I understand that it is necessary to go to the master & nbsp; what is the cost of this job.
what is the cost of this work. It is best to have a solenoid change in the peugeot bit peugeot, a change in the jetta of the archaeologist should have a solenoid change.
08.05.2020 16:36 # 7
cetin
Well, I'm cooled from the car. I'll sell & nbsp; "Unhappy"
08.05.2020 16:36 # 8
fTh206
[QUOTE = tough] Well, I got cold from the car. I'll sell it & nbsp; "Unhappy" [/ QUOTE] will be sold as a failure immediately. In our way, we took out 500 TL, I love the napal, everything we sell right now is mechanical. 0 "alt =" Big smile "title =" Big smile "/>
08.05.2020 16:36 # 9
yigiteroglu
My friend get past. If the malfunction is constantly manifesting, electronic valves need to change, as their friends say. However, if it was for a particular one, the gearbox has locked itself in terms of safety due to a tampering weather or a problem caused by driving. There is nothing to be afraid of if the vehicle does not knock back on the steep ramps if there is no knock in the gearshifts. My only advice is to change the gearbox oil. The services are factory oil, but they are meant to be changed almost everybody in the forum.
08.05.2020 16:36 # 10
metin
[QUOTE = YUNNES37] Greetings
With my automatic 2000 model peugeot 306, yesterday, the snow and sports mode lights started to come on and the vehicle passed out.
What should I do to maintain this gearbox? There is no kidnapping, but maintenance is necessary?
Do the trouble from the cheapest to the expensive. I think it's best to start with an oil change. In addition, if the snow and sports lights are on, this is a message that means there is a fault and it must have created the fault record. You can connect the vehicle to the computer and access the problem from the malfunction code.
08.05.2020 16:36 # 11
[QUOTE = text]
Do the boredom from the cheapest to the expensive. I think it's best to start with an oil change. In addition, if the snow and sports lights are on, this is a message that means there is a fault and it must have created the fault record. You can connect the vehicle to the computer and find the problem from the malfunction code.
Hosgeldin Metin "Clap"
08.05.2020 16:36 # 12
Cmoss06
change the solenoid oil, the problem is solved but do not go away after neglecting
08.05.2020 16:36 # 13
metin
[QUOTE = koliva] [QUOTE = text]
Dear brother, "Smile"
08.05.2020 16:36 # 14
kuantum
[QUOTE = Cmoss06] change solenoid oil problem is solved but don't go away after neglecting [/ QUOTE]
When you say solenoid oil, do you mean transmission oil?
08.05.2020 16:36 # 15
murty973
Hello friends,
My 106's automatic gearbox is not original. I think they adapted from Reno9. The car is not going to the rocket now. Where can I find the track in a cheap way?
Thanks in advance for your help.
1999 Peugeot 106XR 1.4i automatic
08.05.2020 16:36 # 16
metin
[QUOTE = murty973] Hello friends,
Bostancı Avni master who has Day Automatic transmission in the industry. If you haven't met him, I recommend you to meet.
08.05.2020 16:36 # 17
Cmoss06
Change the gearbox oil.
08.05.2020 16:36 # 18
toga406
Don't worry about the delenoids. my car is also 406 auto diesel. Ask him if he does it when he gets stuck and when the oil warms up, he's definitely not in the selenod.
I went to the 2 gearbox master, he said very good gearbox. Another member of the forum that uses 307 is odd, I have changed the solenoids and other parts are the same again.
Don't jump like a carp, go to the master, go to another master. fuck you in your head
