Automatic Transmission
08.05.2020 20:59 # 1
Emregok59
Hello friends
I have written my Transmission problem before (shaking and late sensing when the 1st gear gets up + emptiness when shifting to 2nd gear. . Transmission trouble before If you are a repairman, I would be grateful if you share the solid master and price samples you can recommend in Istanbul with me.
Thanks in advance.
08.05.2020 20:59 # 2
the problem is probably my teacher from the main solenoid valves. It will cost between 600-1000 TL. In addition, do not forget to replace the brake sensor. the pump at the steering wheel is likely to probably help friends from istanbul.
08.05.2020 20:59 # 3
Emregok59
Hello friends
When I was driving the car, I said a faint sound and when I broke the steering wheel to the right, it sounded as if it was rubbing on an iron ground . The problem with gear 1 was from the gearbox and the gearbox wanted revision. an average of 5 thousand rubles.
08.05.2020 20:59 # 4
onlycihan
The new gearbox doesn't cost that much 5000 What do these masters really have to sleep This is the word extortion
08.05.2020 20:59 # 5
EmSul
Has a revision been made? I wonder if the problem is solved
