Automatic Transmission
19.02.2023 15:30 # 1
Mhmttn38
Hello,
My vehicle is a 2005 model Peugeot 407 2.0 gasoline automatic excutive premium model.
The vehicle is at 270 thousand km.
While I am using my vehicle, the speed increases as if I had half-clutch in gear shifting and shifting into gear. it knocks and gives a prnd fault.
I visited a few gearboxes and they say the gearbox will go down and overhaul
It usually makes this mistake, but it doesn't always do it. When I stop and start it again, the problem is fixed
As if the problem will be fixed before the gearbox goes down, but I don't know
Can anyone help me if it has happened before? Please
19.02.2023 17:22 # 2
talip206
Sir, there is a pressure problem. You need to look at the error code. It may be a solenoid failure or a revision may be required. If you force it this way, the worn pads will clog the filter and the vehicle will not run at all.
19.02.2023 21:02 # 3
Mhmttn38
Clutch release failure is seen when looking at the fault. No other fault codes
04.03.2023 11:55 # 4
Redstorm
Hi,
Did you solve the problem? I have the same problem with my 2006 2.0 petrol.
08.03.2023 13:48 # 5
Mhmttn38
Unfortunately I couldn't handle it.
09.03.2023 09:04 # 6
There can be many reasons for this type of problem. Our gearbox masters do not want to deal with their favorite job without checking it properly and examining it. Sometimes the source of such problems can even be the battery. charger connector failure voltage unbalance brake switch oxidation in fuses and sockets frayed even loosely taped cables can cause problems.
