automatic transmission
08.05.2020 19:20 # 1
cihanusta
I can get your questions about automatic transmission here. I will try to help as much as I can.
08.05.2020 19:20 # 2
ttrr171
If you are traveling on the long road, it is 110 at a fixed speed of 3000, while it stops, the gear shifts down and the speed is increasing. especially in hot weather. but it does not light up the fault light
08.05.2020 19:20 # 3
cihanusta
Can I learn the model and year of your vehicle.
08.05.2020 19:20 # 4
ttrr171
2003 model 307 1.6 xt Premium bva
08.05.2020 19:20 # 5
talip206
[QUOTE = cihanusta] I can get your questions about automatic transmission here. I will try to help as much as I can, friends [/ QUOTE]
Hodja is my 2002 model 1.4 206 automatic vehicle. I had a solenoid and oil change 5 thousand km ago. It makes a slight knock when switching from 1st Gear to 2nd Gear after the first start in cold weather. It doesn't make hot air either. I wonder why. They did not update the software after the solenoid was installed.
08.05.2020 19:20 # 6
cihanusta
I recommend you to have your car cooled.
08.05.2020 19:20 # 7
cihanusta
I do not think that the fault you are saying is related to the update, you can do the fault you call from many points.
08.05.2020 19:20 # 8
serhat79
hello my car peugeot 307 xt 2004 model when going on a long road at 135.000 km, it starts to knock and start working loudly when I stop and get up to 90 km, it does not go up more than 90 km, it protects itself when I get triptonik, the d letter remains constant. gearbox landed 14 pads changed. seal changed seal kit changed oil filter changed transmission oil changed 2 times. The cooler heat exchanger behind the gearbox has changed with the big heat exchanger. I have a complete 0 of its own cooling radiator.
When we saw this, the master said from the zodiac signs this time, I don't have much confidence anymore, I will change the zodiac signs, then something else will come out, then I will be crazy .... thank you for your answer in advance.
serhat79 2015-06-22 18:38:23
08.05.2020 19:20 # 9
ttrr171
Serhat Bey have a great past. I don't have the knocking speed, but it gets locked in hot air or when it gets hot. So when I take triptonics when I am at D, I still stay at D. I left it to the service right now, they will change the gearbox cooler. Let's see what will happen.
08.05.2020 19:20 # 10
Mustafa-almanya
Cihan Usta, My vehicle makes a slight push while shifting to 4th gear. Vehicle opel zafira 1,9 diesel. 2006 model. The kilometer is 180000 kilometers. Is it also necessary to change the oil?
Best regards ...
08.05.2020 19:20 # 11
serhat79
Thank you, I made the process done by you, the cooler changed, only the material came to 600 TL, the car's own radiator has changed, but the result has not changed.
08.05.2020 19:20 # 12
ttrr171
urgent help please.
They called from the service now. There is no malfunction in the computer, said the problem can be from eletro valves.
What should I do? I would be glad if you answer..
08.05.2020 19:20 # 13
begk1984
Dear Master,
207 1.4trendy 16V 2tonic 2011
In my car, which I have been using for almost 1 year, it sounds a bit loud as if the door squeak every time you shift. They told me the pressure pad might be finished? What to do is true. They say that the change of pressure pad is a bit difficult in my vehicle and not everyone can.
I am waiting for your help.
08.05.2020 19:20 # 14
cihanusta
As they say, the printing can be from the lining. I recommend you to go to a good place on the recommendations.
08.05.2020 19:20 # 15
cihanusta
Your knock problem may be 2 reasons. I would recommend you to show a master without the proliferation of the brain and the solenoids on it or from the gearbox and you need to change your automatic transmission oils every 30000-40000.
08.05.2020 19:20 # 16
cihanusta
serhat bey (( he starts to knock and starts to work loudly when I stop and get up, he does not go over 90 km, he protects himself when he gets triptonic, the d letter remains constant) The reason for this malfunction is that your vehicle can protect himself from many troubles. switch, which is one of the electronic parts of the gearbox, I recommend you to try
08.05.2020 19:20 # 17
begk1984
My master,
Are you doing it? or do you know a place you can do?
08.05.2020 19:20 # 18
cihanusta
I do not look at the PRINTING BALA business. I am interested in fully automatic cars. If my advice does not cause any problem, the most logical service is that the press does not hurt when it is guaranteed and in the event of a problem in the end.
08.05.2020 19:20 # 19
pierson
Hello .. my s and snow mode was especially flashing in the park .. I went to the master, connected it to the PC .. the electrovans will change ... we changed it ... oil was changed ... ATP put the oil ... I went again..elektrovna gave the malfunction he said it is due to the switch .. he said it will not flash if the switch changes .. what should i do ..
08.05.2020 19:20 # 20
pierson
guncel
Page : / 2
