Automatic transmission
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:57 # 1
Ali0695
Hello friends 1 week ago we bought 2000 model Peugeot 406 st. I think the old type engine D8. We put the car in the computet and the engine performance was 82%, we liked it, we bought a clean vehicle. When the vehicle stops at the lights, it throws itself forward and scares the person, sometimes it does not. Anyway, we changed the passing automatic transmission oil. A few days ago, automatic transmission error gave snow mode and sports mode burned out, stopped and restarted, we continued our way. Gearboxes and other engine masters knock, the general problem of these cars is that they say nothing. Whatever your comment is, whoever we ask is that Peugeot 406 says it chronically, I haven't enjoyed it in a week.
08.05.2020 20:57 # 2
First of all, welcome to us. I wish you to use your vehicle without any accident, good luck. This problem is due to the change in the gearbox oil of my teacher due to the solenoid valves in the gearbox, but I wish it did not change even though the masters knew, and then the workmanship comes out again. This problem is a general problem in al4 gearboxes. the average cost will be around 600-800 TL. Replace the transmission oil.
08.05.2020 20:57 # 3
Ali0695
I asked the master, they looked at replacing the valves, these cars do the same problem again. Thank you for your interest. One more thing I will ask is how many cents it burns in km with LPG gasoline.
08.05.2020 20:57 # 4
Ali0695
I took the car today, changed the solenoid valves, when I changed the automatic transmission oil before, it put 4.5 liters, the master replacing these solenoids put 3 liters back, said it would be more than 4.5, then he deleted the pressure adjustment failure text in his brain and said the s and * lights do not flash, he also tried the tool. He said no, then we went to the gas setting. After a while, the speed started to go late, he made a knock on the 1st and 2nd gears, but after the gas adjustment he was doing this movement and the next day was passing, I wonder if the engine is getting used to the gas adjustment.
