Automatic Shift Stop
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 21:27 # 1
Cannursoy
Hello. Yesterday evening when I was on a slope in the frosty, so it was not a steep slope. The car suddenly stopped. I thought the start stop was the first but it stopped like the manual you know. When I saw the contact turning, I understood that I was very surprised that it stopped. I get the gas from the same place if it coincides. If it does not come from different places and most of the time, I bought 30 rubles during the day and then I did not buy 20 or 50 more petrol. This is the case, the car stopped on a hill, thought stopped for the first time. I did not care for 60 thousand, yet it said there was a slight oil fling, my master said something like it looks like sweating but it doesn't matter. Is this the reason for stopping this? What is it caused by? By the way, I am just learning to drive. Vehicle 2008 1.2 e-vti
08.05.2020 21:27 # 2
FatihBall
the pressure of your car may have lost its feature. If you try again on a steep slope, if it stops again, it is not related to pressure.
08.05.2020 21:27 # 3
Cannursoy
[QUOTE = FatihBall] may have lost the pressure of your car. If the experiment stops again on a steep slope, if it is not related to pressure, the float may have pumped the dirty fuel in the tank while stepping up the steep hill [/ QUOTE]
First of all, thank you for your answer. As you say it can be both. This week, I will always have them checked because I have not had 60 thousand more of them maintained. But it may be what you call a buoy. When I bought the last gasoline, he did not play the needle, then suddenly played it when he put 7-8 liters. The float was stuck. As you said it could be because of the gas.
08.05.2020 21:27 # 4
omerb
hi
I think it may be that you are in a novice period. You already have problems on the slope. :)
You'll fix it in the future. Stop and train on an empty slope. Load less on the gas. Your vehicle is not fully automatic. Stop if you do not give enough gas on the hill. Do not overeat the test pad.
Pleasantly ride a thousand. I think it's a mistake
omerb 2020-02-09 21:58:00
08.05.2020 21:27 # 5
Cannursoy
[QUOTE = omerb] hello.
Hello. Well, you said right, it may be because it came to my inexperience period :) Since I am a very obsessed person, I question such things and unfortunately I am stuck in my mind. I think I have a little bit of paranoia: D thanks for your answer. I would have one more question. Is it normal to see the front torpedo airbag mark? When Tarcanlar watched the appraisal, the person exploded and could not stop without thinking whether it was repaired.
08.05.2020 21:27 # 6
Karacocuk24
[QUOTE = Cannursoy] [QUOTE = omerb] greetings.
[/ QUOTE] You're watching the cinnamon, I need to figure out if there is a coating :)
08.05.2020 21:27 # 7
Cannursoy
[QUOTE = Karacocuk24] [QUOTE = Cannursoy] [QUOTE = omerb] greetings.
[/ QUOTE] You're watching the cinnamon, I need to figure out if there is a coating :) [/ QUOTE]
As far as I can see, it is not covered :) I looked at the ceiling airbags, there was no problem. The airbag script on the torpedo was also normal
