Automatic shift assistance
19.12.2020 20:39 # 1
eryaman
Hello, I have just joined you as a 2011 diesel automatic 308 owner, my problem is jolting in gear shifts and a popping sound that I can not understand whether it is coming from the bottom or from the back at every gear change, let me describe the sound as follows. I would make it look completely at the engine ears, only the lower tire of the gearbox is slightly loose, there is no other problem why this sound is happening, I would be glad if the information that happened to me helps, it was a little long.
19.12.2020 22:27 # 2
Pejjj0.206
Get well soon, you bought my new car
19.12.2020 22:29 # 3
Pejjj0.206
I had the same problem Pejjj0.2062020-12-19 22:31:34
19.12.2020 22:55 # 4
eryaman
Yes, I just bought it, did you solve the problem?
19.12.2020 23:00 # 5
Pejjj0.206
Solved
19.12.2020 23:23 # 6
Pejjj0.206
Did you know when you asked the person you bought?
20.12.2020 00:11 # 7
eryaman
It never caught my attention, how did you solve it
20.12.2020 00:38 # 8
eryaman
I did not ask where the problem came from, we drove for 3 or 4 hours but I never noticed this noise.
20.12.2020 20:02 # 9
Pejjj0.206
I spent a lot of money, I asked the seller, the sound of gunfire sounds like the wheel exploded, I don't know why he said I did not have it said I did not have the throat flap cleaning he said I did the cleaning immediately, he did the cleaning before coming home, I asked what should I do, show it to the carburetor, I went I told him I told him when I changed the ignition coil He said, I changed it again, it made detonation, I asked the master, it did not improve, it did not change the spark plugs, it did not improve, the engine went to cuya said I went I told the crank sensor It changed it did not improve the cylinder adjustment did not improve it said go to the gasman I went to the gasman I went to the gasman I went to the gasman, I changed the gas brain, it did not change the regulator, he said go to the brainman I went to the brainman, looked and said it has nothing to do with me, he said to the exhauster, he said, go to the exhauster, I went to the exhauster, I told the exhaustor about my problem, I changed the exhaust, I changed it ZERO, it did not work, I was confused, what will I do, I am cooled from the car, my brother-in-law has caught the car's operation and called me my father-in-law car sound change You said it comes from the exhaust, and it comes from the exhaust, I said it can't be destroyed, this sound is not normal. There is no catalyst, he said it would explode, I was surprised I said expensive, I said if it explodes I will not give money, he said, do not give the catalyst, my brother said, I put the catalyst on the test drive I went for a test drive it did not explode, I extended it, I made it 60.70 kilometers, it did not explode, as it turns out my problem was the catalyst.
20.12.2020 20:30 # 10
eryaman
My brother, you have tried very hard to get past, I am glad that it was resolved at the end. The sound I mentioned is only coming when changing gears, a master said that it comes from the rear balance arm and chocks.We will change the wedges first, we will see if it costs 1000 TL, if it does not get straight from the wedges, it is necessary to change the balance arm, but the room holds a price of 7000 lira. I didn't believe it, it doesn't hurt for now. I manage like this. I hope it won't cause any trouble.
20.12.2020 20:38 # 11
Pejjj0.206
The voice in me does not come out on the streets.When I was traveling at 50.60.70 kilometers, when I took my foot off the gas, it makes a sound like the wheel bursts PAAATT paatt like mine
20.12.2020 21:25 # 12
eryaman
My brother's voice is not like you said, it comes in gear shifts, it just sounds like a tire sound like pıt pıt when passing through the joints on the bridge at night from the road joints on the asphalt, and when I use the manual and change the gear myself, I will see if it will come again.
20.12.2020 21:36 # 13
Pejjj0.206
Get well soon talk to the person you bought, give it back, I say don't try, you know or financial aid
