Automatic headlight problem |
| 27.06.2020 18:10 | # 1 |
| 28.06.2020 01:16 | # 2 |
I have never heard that the high beam is burning with the sensor, the sensor turns the low beam on and off, the high beam works by pulling the handle or flashing. In the dipped beam it burns only to a certain darkness
| 28.06.2020 14:17 | # 3 |
First of all thank you for the reply. Yes, I think the system looks normal, but he says why it does not switch to high beam when switched to Manuel mode. If there was a problem in the arm or elsewhere, it would not work in the dark. It is a problem not to switch to high beam in manual mode.
| 11.07.2020 14:19 | # 4 |
Does anyone else have this problem?
| 11.07.2020 16:29 | # 5 |
kaan206 |
[QUOTE = Lancelotx] Anyone else having this problem? [/ QUOTE]? kaan2062020-07-11 16:30:56
| 11.07.2020 23:45 | # 6 |
Why does the high beam not turn on when switched to manual mode? In Auto mode, it normally lights up at night or in a tunnel. So there is no problem in the arm, in the headlight. But high beam did not work at the inspection station. It works at night. We put it in Manual mode to look at it during the daytime or on examination. I couldn't explain to them either
