AUTOMATIC GLASS LIFTING PROBLEM |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:23 | # 1 |
| 08.05.2020 16:23 | # 2 |
güncellll p> |
| 08.05.2020 16:23 | # 3 |
you will open the ignition of the vehicle and hold the windshield lift buttons up to 10 seconds in the direction of lifting up, my friend.
| 08.05.2020 16:23 | # 4 |
Thank you for the information.
| 08.05.2020 16:23 | # 5 |
well, will sunruffto be active in this way? |
| 08.05.2020 16:23 | # 6 |
erkerd5429 |
I had to remove the polar heads on Friday, the rear window is raised, the sunroof is closing, the windscreen is not closing, I hope I can fix it in the same way.
| 08.05.2020 16:23 | # 7 |
erkerd5429 |
[QUOTE = peugeotefe] You will open the ignition of the vehicle and hold the windshield lift buttons for 10 seconds in the direction of lifting up, my friend will be activated [/ QUOTE] exactly the same problem is solved
| 08.05.2020 16:23 | # 8 |
Make the sunroof fully opened upwards and hold the button in for 3-4 seconds will correct.Also if you lock the car when the sunroof is open (if the sunroof is closed with lock), then when you open the car again, the sunroof will return to its open position.
