AUTOMATIC GEARBOX HEATING PROBLEM
08.05.2020 15:00 # 1
metin
As friends are known, when the temperature rises in the 307 1.6 automatic gears, the gearbox is heated in the oil, hitting the gearshifts, naturally, then it opens up expense and goes to the revision. I wonder if friends who can give an idea that can solve this warming problem, please do not withhold your comments, especially friends who have knowledge about the cooling system, let us share this information, everyone respects this problem.
quiet_20 2010-12-29 16:33:02
08.05.2020 15:00 # 2
qw12
I think the 2006 model and above had a radiator different from the old ones, cooling better. I have read a few articles on the Internet that it is good to replace the radiator of older models with them, but I do not know how accurate.
08.05.2020 15:00 # 3
metin
I also read the make-up case radiators, but some say the same, some say different, so it doesn't fit, I don't understand.
08.05.2020 15:00 # 4
Kifanhom
If you install a thick type radiator suitable for your vehicle, I think your problem will be solved
not necessarily for peugeot
can fit in other brands in height and height
looking a bit troublesome
but the result is really good
08.05.2020 15:00 # 5
metin
I will investigate the logical you call. eccentric seals of the vehicle have to be changed, this is my first job after I take care of it, regards.
