Automatic gearbox has inflicted the problem
08.05.2020 21:10 # 1
gorkemgorgunx
hi aleyküm my vehicle 207 1.6 vti automatic 2008 model 186 thousand has a transmission problem in the first time in the morning, the vehicle does not malfunction but when it shifts, it makes a hard knock at the gears, it fails before going 500 meters and after the fault light comes on, it shifts to all the gears. It changes, the oil changes, it can give the same fault again. Is there
08.05.2020 21:10 # 2
So, what error codes does my teacher give when he connects to the device. The master has now replaced two possible main solenoid valves. Other solenoid valves providing vires passages may also be problematic. which gearboxes did you take? Probably your problem seems to be related to pressure, but.
08.05.2020 21:10 # 3
Yok
I follow the subject. Similar situations have occurred in my vehicle recently. Moreover, my vehicle had seen the Gearbox revision 1 year ago due to the same problems. It is annoying to relapse again. I plan to go back to the place where I have revised for annual inspection and maintenance, or it could be a place that can remove the fault code of my car or know the Pejo language that understands this issue; I'm in research. Because there is no computer in the revision. I can get your expert advice that can make point shots and understand from automatic gear for the Anatolian side of Istanbul. Hope to solve your problem ..
