automatic gearbox d remains too?
08.05.2020 16:22 # 1
ismail ozdemir
I have my friends 307xt 2002, my car did something like 2 times after the weather got cold: I run the car, I am heating it, I get it as if it is as if it was passing, it is difficult to move it, then it is difficult, then it stops, it is difficult to get lost and when it passes back to d, it becomes harder again. It also leaves the automatic gear error when it does the 2nd time, the problem disappears when I stop and run it again. It does not always happen, usually when I run at -5 -6 degrees at night
08.05.2020 16:22 # 2
peugeotefe
When was the last transmission oil changed?
08.05.2020 16:22 # 3
ismail ozdemir
I bought the vehicle on 14.05.2010, I bought 113.000km, I think the car is 133.000km and I guess I didn't change it before me.
08.05.2020 16:22 # 4
peugeotefe
Then you should change the gearbox oil.
08.05.2020 16:22 # 5
ismail ozdemir
I don't have any problems, I don't know, I don't have any problems. no problem, right?
08.05.2020 16:22 # 6
peugeotefe
& nbsp; What can be harmful to when changing oil, on the contrary, it has benefits.
08.05.2020 16:22 # 7
ismail ozdemir
arrow. Is the service most logical for this job?
08.05.2020 16:22 # 8
peugeotefe
It is not necessary to have an authorized dealer in the province, it will help if you go to a master.
08.05.2020 16:22 # 9
bayelektronik
Since my friend has experienced this problem before and it is a chronic problem, I say that replace oil and electrovan or solenoid valves with the other name. The problem disappears completely.
08.05.2020 16:22 # 10
ismail ozdemir
I guess you had the same problem, I guess it doesn't function properly in cold weather because it loses the right oil feature because I think the problem disappears when I stop and restart it after the car warms up, so I do a lot of damage to the gearbox?
08.05.2020 16:22 # 11
berk2309
If the oil has not changed, it is useful to change it, connect the trainee and the computer and measure the solenoid pressures & nbsp; If your vehicle is 307 in case of old and has never changed its solenoids, it is better to replace it if there is no new type of solenoid & nbsp;
08.05.2020 16:22 # 12
gravis_pro
My 2000 model Scenic also had the same problem. It was made of annoyants called Micropilot. They said it was stuck at 2.000 TL in time. They described one of the automatic gearboxers in Maslak industry. I hope it is not that expensive.
08.05.2020 16:22 # 13
ismail ozdemir
I do not know if the old case has changed from 307 or not. I have a look at my building for a couple of months.
08.05.2020 16:22 # 14
If there is a new type of valve, you will hear a scratch. In old types this scratch does not come. This scratch is hardly heard from the vehicle, but it is obvious from the outside of the vehicle. Bosta does not happen in two "Geek"
koliva 2011- 11-19 12:13:23
