automatic gear shifts
08.05.2020 17:26 # 1
secur73
friends how are the normal gear shifts in automatic arcs * my vehicle passes from 1 to 2 at 1900 * 2 to 3 at 2100 and sometimes & nbsp; I have 3000 from 3 to 4. When one of my friends passes 2400, he pretends to pull his feet out of the gas and when I do, he says that normal gear shifts, my question is this problem?
08.05.2020 17:26 # 2
Burak
I had 106 auto, which is pretty much a normal problem, I think.
08.05.2020 17:26 # 3
arachnid
just like that in my car. I think pressing the gas is & nbsp; decisive & nbsp; If you want it to pass before 3000, it will pass if you do as your friend says. You can even see 4500-5000 rpm depending on the throttle and road condition (very light uphill ) until 4 passes. & Nbsp;
08.05.2020 17:26 # 4
fxmen
my friend everything is perfectly normal don't worry :)
08.05.2020 17:26 # 5
terzuu
hi,
friends change according to the driving characteristics of the automatic gear shifts driver and the engine values of the vehicle. How do you say that the porsh 4 gear used in the pejo does not remember the time interval of the user, but let's say that whatever you used the vehicle in the last half hour, it keeps the values in memory and organizes the transitions accordingly.
When using
normal, it will be limited and gassed when using it at normal values for a certain period of time. this pejo. It is a joke but it changes the transitions by considering the motor values based on previous use values to give full response to the user's character. When it comes to 2000 cycles, there is no software to replace it.There is a different way of appealing to everyone since every user is different to drive. Use the vehicle at maximum values for 1 hour, then start using it normally. As soon as the vehicle does not go to you, the normal transitions begin after a certain period of time after the transitions are abnormal.
tailor 2013-03 -14 23:29:57
08.05.2020 17:26 # 6
foresteng.
nerdeeee these ranges .. 2700-3500-4200 rpm.
08.05.2020 17:26 # 7
metin
It is normal that shift speeds differ depending on the way you press the gas. For example, when it is lifted with full throttle, it even finds 8000 revolutions.
08.05.2020 17:26 # 8
msertkol
This happened to me on the highway. I went with 130km / h constantly. I stopped, took a break, about 1 minute. I ran it again. The car moved into 2nd gear at 3500 rpm. Moreover, I was slowly loading the gas. I noticed much later. Let's say the car threw at 4, take your foot off the gas, but not to 3. So use non-spinning. Then economy returns to mode. I was worried, but thank goodness the car is recovering.
08.05.2020 17:26 # 9
osterreich
my ASG has gone at high speed for a long time at 6 gears while falling from 2 to 1 and N to D & nbsp; when importing to gumm & nbsp; He shoots officially from the car, the previous peugeot 807 im porsh 4 gear was not there, but I did not solve this ASG 6
