automatic gear shifts
08.05.2020 17:13 # 1
secur73
friends, my automatic vehicle 1 and 2 gears pass in 2000 and 2500, but 3 gears often pass in 3000_3300. Any malfunction indicator is not lit.
08.05.2020 17:13 # 2
secur73
friends & nbsp; Does anyone have an opinion on this matter ... I would be glad if you could help ...
08.05.2020 17:13 # 3
cinar87
It is useful to show 4 transmissions
08.05.2020 17:13 # 4
foresteng.
[QUOTE = secur73] my friends auto 1 and 2 gears pass in 2000 and 2500 but 3 gears pass frequently in 3000_3300. 3500 rpm from 2 to 2; From 2 to 3 to 4000; It ranges from 3 to 4 to 4500 rpm. But there is no article, I also went to the service .. There was no error on the computer, but it bothers me, the car shouts and shifts ..
I also use manual ...
08.05.2020 17:13 # 5
Peregrin
You can know that the shift speeds may differ depending on the use of AL4 in automatic gear. It beats at higher revs in aggressive use.
A fine point for gear up; When you step on the gas, when you come to a certain speed, you can increase the gears when you cut your foot slightly from the gas. Peregrin 2012-12-21 12:53:52
08.05.2020 17:13 # 6
secur73
yes, you are right, aggressive use at high speed, it is normal, so we can say that it is normal.
08.05.2020 17:13 # 7
tolga35
the service saying it has eaten !!! the oil does not deteriorate contrary to the nature of the item. km is 40000 and if you see the oil & nbsp;
you will regret that you have not changed it anyway ...
08.05.2020 17:13 # 8
foresteng.
[QUOTE = Peregrin] You can know that shift speeds may differ depending on the use of AL4 in automatic gear. It beats at higher revs in aggressive use.
A fine point for gear up; When you step on the gas, when you come to a certain speed, you can increase the gears when you cut your foot slightly from the gas. ]
This is a fact .. & nbsp; but no matter how you use it, it reads that you know it .. it doesn't let the entresan make a mistake ..
