Automatic gear shifts
08.05.2020 21:15 # 1
byrm7
Hello everyone, I am sorry if I was hungry, I was following the fot for a long time, but I became a new member, there are those who are stuck in my head, I had problems with the press and my friends and experiences and suggestions can help me to come to an easier conclusion.
407 2.0 automatic (2006) There is a situation like throwing forward not a knock when shifting from 1st gear to 2. Although it is not felt much when it is put into gear, there is a sound called click, there is no kidnapping on the ramp or mound, the thought is automatic when you think it is automatic. I would
08.05.2020 21:15 # 2
My teacher usually has a few reasons for this type of troubles.
1-Brake sensor replacement can be corrected, you can even replace a cheap piece yourself. It has a price of around 50-60 TL.
2-transmission solenoids (valve) may be a problem. The vehicle must be connected with the PC and the pressure values must be checked. It can be corrected by transmission oil and replacement of these parts. It costs around 800-1000 TL.
In addition, what is the type of transmission in your vehicle. 4 forward or 6 forward type. 6 advanced am6 type gearboxes were used in the diesel
08.05.2020 21:15 # 3
byrm7
4 advanced teachers (al4)
While the vehicle is being pulled out, it usually does, there is a slight click in reverse gear, which I said, can I replace the solenoids in auto-repairers? Can you update it or something
08.05.2020 21:15 # 4
they can do it hodja. already installed valves should be introduced to the vehicle. you can get the update done at authorized services. But first of all, I would say replace a brake sensor and observe it.
08.05.2020 21:15 # 5
byrm7
Thank you very much for your interest, I will change it at the earliest opportunity, so when the brake sender writes, it comes out in different types, which one did not resolve, even you change it yourself?
Bidet, I think of the battery, can this cause what I have told, so if the values are low?
08.05.2020 21:15 # 6
it will be better to buy the brake sensor from the peugeot spare part with chassis. There are many videos of video sites like youtube teacher. simple to change
08.05.2020 21:15 # 7
byrm7
I watched a few videos seem easy as you said, I will provide the part at the first opportunity and take care of it. Well, could the problem I wrote first be related to the light knock at the bites nights?
08.05.2020 21:15 # 8
byrm7
[QUOTE]
I have free time on Tuesday, I will go and take care of it, he looked at the piece, he said 35 lira
Sir, I looked at both the car when it was cold and when it was hot, there are knocks in 3 gears and 4 gears. I have a question, teacher
Is there anything you can say try on the car? (Like diagnosing the health and condition of the suspect)
There is a lpg in the vehicle.
08.05.2020 21:15 # 9
Unfortunately, many authorized services do not look at LPG vehicles. Is there an electric part that is added to your vehicle as well as sound system-exnon. it can cause trouble in these parts. I, for example, control the fuses by removing them once a year. including the sockets I could reach.
08.05.2020 21:15 # 10
byrm7
There is not even a mixed paint, I did not wear it externally, it was not attached to any electrical or electronic parts. the air filter is looking at the throat butterfly, I think I look at the oil of the solenoid. It is not
08.05.2020 21:15 # 11
My teacher, I always have a master I go to, if you want, sometime myself will help with the transmission. The peugeot special service is looking at the error codes with the original software in their hands, and electronic and electrical masters are also available.
mas peugeot abdullah master: 0537 964 58 20
08.05.2020 21:15 # 12
byrm7
I need someone I can trust so much about price and mastery, where is the place?
08.05.2020 21:15 # 13
byrm7
Also, my teacher pressed the brakes, the speed stops, the vehicle did not give an error code, but I turned off the malfunctioning lamp, but again, the rich wife gave the error. byrm7 2019-06-30 23:13:16
08.05.2020 21:15 # 14
byrm7
[QUOTE = sonerkyl] My teacher has a master I go to all the time. If you want, my skin will help himself in the transmission. The peugeot special service is looking at the error codes with the original software in their hands, and electronic and electrical masters are also available.
Also, my teacher pressed the brake, the cycle stops, the vehicle did not give an error code, but I turned off the malfunctioning lamp, but it responded again, the rich wife gave me an error.
