automatic gear questions
08.05.2020 17:12 # 1
pierson
My vehicle 206 xr 1.4 ... what do I mean when the number 2 and 3 in the gearbox mean? when should I use it? > thank you ...
08.05.2020 17:12 # 2
Barut
If 2 and 3 are working manually, if d is automatic, if s and snowflake icons are flashing, there is a problem in the gearbox, friends who know will help in more detail.
08.05.2020 17:12 # 3
pierson
what could be the problem in the transmission ... I changed the back board of the instrument panel sometime ... the coolant hand was not working ... could it be caused by it?
08.05.2020 17:12 # 4
Barut
I know if the selonite valves need to be replaced it costs around 500
08.05.2020 17:12 # 5
pierson
So what is this replacement ... what happens ... is it okay?
08.05.2020 17:12 # 6
Burak
S is generally used as a sport gear in automatic cars, but I have never used an automatic 206 automatic in my vehicle 106
08.05.2020 17:12 # 7
Barut
[QUOTE = pierson] so replacing this part ... what happens ... would it be a problem? [/ QUOTE] yes it causes bigger problems, the transmission protects itself when the s and snow marks are lit, usually makes it from the selonid valves but other than the valve The problem may arise with the best chance it costs 500 600 TL, I think you should take it into account, or the gearbox may even ask for refit and the cost will be 3 thousand.
08.05.2020 17:12 # 8
pierson
Well if I do not take 2 or 3 ... I always use D ... I said that there was nothing like that ... I changed the backside board of the instrument panel .... after that it must have happened ...
08.05.2020 17:12 # 9
Barut
[QUOTE = pierson] Well if I don't get 2 or 3 ... I always use it in D ... I said that there was nothing like this ... I changed the backside board of the instrument panel .... after that it must have happened ... [/ QUOTE ] if it does not do it in the d position, use that shape, my teacher should be on the display, I think it should be connected to a little computer.
08.05.2020 17:12 # 10
pierson
where can I connect to the computer ... how much computer to connect ...
08.05.2020 17:12 # 11
Barut
[QUOTE = pierson] where can I connect to the computer ... how much computer to connect ... [/ QUOTE] You can connect to the services with p2000 program, teacher fee is 20 TL.
08.05.2020 17:12 # 12
pierson
thank you
