Automatic gear problem
08.05.2020 20:34 # 1
MB.5206
Hi guys I bought a pegout 207 automatic gear about a month ago. Yesterday when I parked my car, I pulled the hand brake and bought it, then I forgot it before I closed the contact, and I left the ignition for about 8 hours. Then, while my wife was running, he said that you did not take it to p, he took it to r and went back to d, then the car suddenly started to vibrate like a tractor, he stepped forward, the car went back, I said "press the brake, I don't stop," he said. Then we took the p, closed the ignition and started the vehicle properly. And a week ago, different sounds came from the engine, what do you think could be like a grunt?
08.05.2020 20:34 # 2
First of all, welcome to us. n is already idle, my teacher will not create a situation that will cause you to stop. but I guess the vehicle doesn't recognize gearshifts as there is a problem. First of all, connect the pc and look for the fault codes, but to a special service with a peugeot software, other universal devices may not see some error codes. I'll tell you what to do
1-Replace the brake sensor.
Make the 2-gear calibration.
3-Motor ears for vibration in motor etc. be checked.
4-vehicle lpg do you have?
5-idle ripple etc. Is there?
08.05.2020 20:34 # 3
MB.5206
Zavoli brand has a lpg, it is newly installed, idling also fluctuates. I run the vehicle for the first time because we have just learned, we do not suddenly press the gas when we get up.
08.05.2020 20:34 # 4
I understood, my teacher, the general problem of semi-automatic is that you live. If you perform a calibration calibration, the tremor event will be minimized.
08.05.2020 20:34 # 5
MB.5206
Hodja alone, the car is fully automatic, I don't understand why. When I asked the father-in-law, he looked a little good, he said it seems no problem.
08.05.2020 20:34 # 6
pardon teacher full 207 automated in the market, there is not much or even very few. I think if your vehicle has 1.6 engine, if it has shaking, have the engine and transmission chocks checked.
08.05.2020 20:34 # 7
talip206
I think a temporary situation has occurred. If you tried to change gear without pressing the brake, the head may be confused.
I don't think he'll do it again
08.05.2020 20:34 # 8
it may be exactly as you said suitor. Many automatic transmission problems are already caused by trying to change gear without stopping the vehicle.
08.05.2020 20:34 # 9
MB.5206
Thank you everyone
08.05.2020 20:34 # 10
talip206
[QUOTE = MB.5206] Thank you to everyone [/ QUOTE]
As far as I understand you are using the new automatic. Minor situations, voices may react differently. Don't worry too much. You get used to it over time.
Let me give some advice. Do not change gears without fully applying the brake.
Do not change gears without stopping.
When parking, apply the load to the parking brake, not the gear. In other words, put the gear in neutral, apply the hand brake, pull your foot off the brake and get on the load brake. Then press the brake and get to P.
08.05.2020 20:34 # 11
MB.5206
Yes, I am driving a new vehicle since August 16, it has been staked once again today. Once I stepped on the gas, it was at 10, but the needle went up to 20 I did not stop, I did not stop, I stopped with the hand brake, this may be the reason. I asked a master, said no problem No use error, laughed
08.05.2020 20:34 # 12
talip206
[QUOTE = MB.5206] Yes, I'm driving a new vehicle since August 16, it has been staked once again today. Once I stepped on the gas, it was at 10, but the needle went up to 20 I did not stop, I did not stop, I stopped with the hand brake, this may be the reason. I asked a master, said no trouble No use error, laughed [/ QUOTE]
Automatic car does not stop, easy, easy. It had happened to me when the lpg setting was made, it did not stop again. If it stopped while in the gas, go to the LPG and tell the situation. The fact of not stopping was interesting. Well, when he doesn't stop, is he giving himself gas? If it does not stop when it stops, the brake is swollen, normal condition, but if it does not stop when it is running, another talip206 2017-09-19 22:00:06
08.05.2020 20:34 # 13
MB.5206
Istop incident was like this, my teacher, we were on a slight slope, gas was 10 or something. The brake event was going today, the speed was still low, I pressed, the speed does not increase, while the pointer rises hard and hard, I pressed the brake, but it did not slow down. I pulled the handbrake, started it again, no problem, kept the brake
08.05.2020 20:34 # 14
talip206
[QUOTE = MB.5206] The İstop incident was like this, we were on a slight slope, gas was 10 or so. The brake event was going today, the speed was still low, I pressed, the speed does not increase, while the pointer rises hard and hard, I pressed the brake, but it did not slow down. I pulled the handbrake, started it again, no problem, kept the brake [/ QUOTE]
I understand, it is good to show it to a good master. The stop event is solved with the lpg setting. But you have to look at the issue of not going and not stopping.
08.05.2020 20:34 # 15
MB.5206
Greetings my friends, I press the car to the gas, it does not go, and then I run it again, and it did it twice. What can be the problem today?
08.05.2020 20:34 # 16
talip206
[QUOTE = MB.5206] Greetings my friends, I press the car to the gas, it does not go, and then I run it again, it does it twice. What can be the problem today?
Probably the transmission is protecting itself. When taken under protection, it does not take off in 1st gear. so as soon as he shouts. You need to show it to your transmission master. It usually does because of its automatic gear solenoids. Along with the solenoid, transmission oil changes. But show it to a good transmission master for the final result talip206 2017-09-24 16:46:27
08.05.2020 20:34 # 17
MB.5206
When I pressed the gas, it did not go away, nor did it sound at all. When you run it again, this time it wants to escape fast and sometimes it gets faster. Is there a good master or service in Istanbul you know
08.05.2020 20:34 # 18
talip206
[QUOTE = MB.5206] When I pressed the gas, it did not go away at all, and my teacher did not make a sound. When you run it again, this time it wants to escape fast and sometimes it gets faster. Is there any good master or service in Istanbul you know [/ QUOTE]
If there is no shout, then there is no transmission shortage. Unfortunately I have no idea about the master. If there is no master you trust, authorized service is the best. But friends who know help.
08.05.2020 20:34 # 19
Karacocuk24
I looked at all the comments from start to finish, the job is a bit complicated for the first time, you started driving this car, so if you are in the process of getting to know the car, you can give an example, but don't take it on you. According to the desire to move forward, it can stand a little harder, but because of this, my friend was experiencing the problem because he pressed the brakes with his big shoe and he stepped on the gas without being aware of the shoe edge. If the people around you say it's okay, I hope that it will pass when you get to know a little vehicle.
08.05.2020 20:34 # 20
MB.5206
Yes, this is my first car, today, the speed has stabilized and I immediately bought it in gasoline. And since the vehicle's screen also says depollution system faulty, I looked through the net and says dirty fuel. It is my first time using it for about 40 days. There was no problem with the brake, only when the first start in the morning the light vehicle was shaking, it was the morning when it was getting back today
Page : / 2
