AUTOMATIC GEAR PROBLEM
08.05.2020 19:19 # 1
akemal
Hello friends.307 1.6 I have a automatic gearbox. 1 month ago I changed the solenoids because of the knock, then I had no problems after 2 days, when the gear shift was changed from time to time from D to R, the snow and sports mode signal burned on the screen. I would be glad if there could be help with this issue?
08.05.2020 19:19 # 2
berk2309
Is it possible to tell my teacher when I change the gear position or just do it when I am on the road
08.05.2020 19:19 # 3
akemal
doing it when I change gear
08.05.2020 19:19 # 4
talip206
Hodja, does it sound when you press the brake? If it does not, the brake linkage is malfunctioning and delivers and warns when shifting. If the brake is not blocked, there may be a shift position switch. On rainy days when it is rainy, it can do because the gear position switch sockets are wet.
08.05.2020 19:19 # 5
akemal
There is no problem with gear shifting, teacher, no sound or anything. After the solenoid change, everything was normal.
