automatic gear problem
08.05.2020 14:51 # 1
EMRE
When I left today, I noticed that the car was not working when I stopped at the lights and then when I left, the rocketing was not working. pips sounded exactly when I was going to the military, I feel like I am hungry Ouch
08.05.2020 14:51 # 2
arifkemal
the same happened to me
problem transmission valves. needs to be replaced. is something in every car. after a while, it loses its function. It is around 400 TL. you will be the only one to overtake after changing. you understand the difference ohh be said :)
08.05.2020 14:51 # 3
deniz_206
Well it cost 400 lira.
08.05.2020 14:51 # 4
EMRE
400 mu Confused full expense foot ii expense door opened car Gülme
08.05.2020 14:51 # 5
haruncoskun
may also be rocket wire
08.05.2020 14:51 # 6
EMRE
construct. The wire is cheap, I will see you take it to the master tomorrow, what is it? Sırıtma
08.05.2020 14:51 # 7
haruncoskun
rocket wire ( throttle wire) is great if it does n't kick down only in bottom gas
08.05.2020 14:51 # 8
EMRE
at work, he does not launch, he has difficulty getting up, yesterday, I said I couldn't overtake the dolmus yesterday, he used to throw the gas, I couldn't feed it, he entered 50 with 50 when he climbed the slope fell to 20
08.05.2020 14:51 # 9
haruncoskun
I hope you will say there is a wire or you will have a lot of expenses
08.05.2020 14:51 # 10
EMRE
gearbox oil low? Somebody said he got stuck in my head, can we look at the transmission oil, how much is there any shortage?
08.05.2020 14:51 # 11
yzt06
90% transmission valves ... like doing the same problem with me these days:) have to be put in the computer ...
08.05.2020 14:51 # 12
Onur
it doesn't have anything to do with the rocket wire kick down, the sports snow lights won't burn out
08.05.2020 14:51 # 13
EMRE
I went to my own master, there was no problem in the wafers, what is biston? What is the probability of wearing them? The gearbox had to be disassembled and looked after. If I had found one or another fault, I would take the full answer to the service tomorrow and get the answer and get the answer. Gülme
08.05.2020 14:51 # 14
EMRE
I am having a great shock peugeot service, a price of 4000 TL for the gearbox, my head was a little Confused
08.05.2020 14:51 # 15
tayfunyesilyurt
offf get past, i hope the problem will be solved in the most convenient way ..
08.05.2020 14:51 # 16
yzt06
What was the problem? Did you find out what was the problem holding 4000 lira? as far as I understand from the valves ...
08.05.2020 14:51 # 17
EMRE
service does not give information only says that the gearbox will be in istanbul, i found a master who understands the gearbox in izmir today. Sırıtma
08.05.2020 14:51 # 18
hantsome28
If you give information from the result, we would be glad ... I have triptonics.
08.05.2020 14:51 # 19
bayelektronik
My teachers do not repair the services directly. valve or electro valve 500 lira no room hydraulic block I think it will be 1300 lira change
