Automatic Gear Problem
08.05.2020 20:16 # 1
ayhnasal
2001 Model 1.4 XR OV. I have a car of 106,000 km. My car never fitted with LPG.
Sometimes, when I shift the gear to the d or r position, it spins up automatically for a short time like 5 seconds and then shifts into gear.
What might be the problem?
08.05.2020 20:16 # 2
First of all, welcome to us. teacher, change the brake sensor, if it does not improve, you need to connect with the computer and look at the error code.
08.05.2020 20:16 # 3
ayhnasal
Thank you, thanks. Even if you don't feel that there is no problem in gear shifts, it is the place to say. It does not give any errors on the computer. it does not light up the fault. As you said, let me take a look at the brake sensor. It only does it at first, it is more difficult to start when the engine is cold.
08.05.2020 20:16 # 4
KILIC
I think it's a normal situation, teacher. When you take it to D or R, the vehicle perceives the desire to go, so it is normal to give a light gas. A situation that should happen so that it does not get behind easily on slopes or when you pull your foot from the brake. Is it stuck in position P, is there a problem with the gear lever pull? If it is stuck, definitely replace the brake sensor. If you already have a 20-25 TL piece, you can even replace it. Do you press the brakes fully or do you press halfway during gear changes?
08.05.2020 20:16 # 5
ayhnasal
I fully depress the brake during gear changes. Don't miss out etc. There is no problem, only if the car is cold, when it is put into gear at the first start, it gives a throttle for 2-5 seconds, then it shifts into gear. During this time, the light blinks at the n position and not the d position, then switches to d.
