Automatic Gear Problem
08.05.2020 18:01 # 1
peugeotolcay
Friends 2004 206 auto. In my gear car, the vehicle malfunctions in the N or P position, this happens every now and then. Does anyone have any idea about why?
08.05.2020 18:01 # 2
mami202
Can you explain a little more in detail how the malfunction stops the engine or transmission error warning etc. The're coming.
08.05.2020 18:01 # 3
peugeotolcay
The vehicle and the snow mode are blinking while the vehicle is not stopping. but the malfunction is only in the n and p position, there is no trouble on the go
08.05.2020 18:01 # 4
pierson
[QUOTE = peugeotolcay] vehicle is not stating in standby state, and snow mode is blinking. but the malfunction is only in the position of n and p, there is no trouble while driving [/ QUOTE]
I have the same situation altogether ... I wonder why it may be? I asked the master, he said what the solenoid valves will change. What should we do?
08.05.2020 18:01 # 5
berk2309
While throwing it to n and p, it is wrong to detect the position sensor from the shortage of the gear rope.
08.05.2020 18:01 # 6
pierson
actual
08.05.2020 18:01 # 7
mami202
because my car's gearbox is defective
Be sure to connect the vehicle to the computer and get the transmission related data.
I think that there will be an error warning about oil pressure or sensors, I can not say anything related to sensors but
Do not change the electrovalve and oil in case the master said according to the head. Show again to places in other computers linker to make sure that after thoroughly (if necessary) valve - book oil change. If it does not improve after you replace oil and valves
they will say that the filter must change, then the converter pads etc .. If you will make a change, the list will go on and it will be good and reliable and they will start to say that the gearbox will be completely revised. a simple malfunction can go up to events that will result in 3-4 thousand liras. pleasant driving.
mami202 2013-10-31 20:11:32
08.05.2020 18:01 # 8
pierson
If we connect the vehicle to the computer, will we see where the fault is?
08.05.2020 18:01 # 9
mami202
Let me give an example as follows.
I was warning that the exhaust emission system on my vehicle's screen was defective (with the engine warning icon).
Lastly, an exhauster first connect it to the machine, then if the problem is catalytic, I said as I said, I did an injection error warning on the screen.
If the computer is already scanned after the vehicle is scanned, the errors will be displayed on the screen, at least including the gearbox allows you to get the right idea.
mami202 2013-10-31 21:57:34
08.05.2020 18:01 # 10
peugeotolcay
After my car's electro valves changed, I was making such a situation, it was giving it while it was already on the road, while it was waiting, I started to give it while waiting. Interestingly, when you connect it to the machine, there is a functional error in the machine as if the gear lever mechanism is wrong :(
08.05.2020 18:01 # 11
pierson
When it is connected to the computer, does all the malfunctions occur? Is there a master peugeot computer program?
