Automatic gear knock and late shift problem
08.05.2020 18:49 # 1
enes_468
hi friends 1.4 auto gear petrol & lpg car 120 thousand km. I have 2004 model car recently, while the 2nd and 3rd gear shifts, sometimes slightly violent knocks passes to 4, until the 5 thousand revolutions are reached, the vehicle does not pass to 4 yells and then knocks and passes. There is no problem in the traction. (ATTENTION HERE) There is NO FLASHING IN THE SNOW AND SPORTS LIGHTS, so it does not give any warning. Someone of the master said that the solenoids will change, someone said, a full revision, someone says that the sport or snow lamp should flash in order for the solenoids to change. The same master says that if the oil changes, the same knock can continue even if the solenoid changes. I am amazed at what to do, your ideas are very important to me. I am now loving one by one for your responses. enes_468 2014-10-20 00:42:51
08.05.2020 18:49 # 2
eyup.clk
Brother, no, I will have a question for you. Have you tried the car in petrol?
08.05.2020 18:49 # 3
enes_468
YES I HAVE A FRIEND, I HAVE A HIT ON THE GASOLINE.
08.05.2020 18:49 # 4
dream
My friend, I had the same problems. First you need to change the gearbox oil, then change the electrovalves inside the gearbox (usually one fails but it is healthy to change both)
And finally, have the ears of the motor checked. Most likely there will be no problems.
But have them all done at the authorized service. You pay a little more, but at least you have a business partner.
The complete overhaul of the transmission takes about 4-5 thousand
If you want to install a new transmission, you will spend 8 thousand.
You should also consider these.
Good luck with.
08.05.2020 18:49 # 5
hasanucar
I am the first to hear that when the snow and sports lamps flash, the seloneids need to change, and I have something in my car; There is another gap between N and D in gear, so when I slowly pull from N to D, if I do not pull the gear fully and leave it in that space, the sports and snow lamps are flashing. This is always the same. But if I throw the guy on smart D or pull it directly to 3, there is no problem. hasanuc is 2015-02-01 17:48:34
08.05.2020 18:49 # 6
enes_468
dude this tool I am told is difficult to keep my gras out of order. See if there is an error code connect to pc in the service.
08.05.2020 18:49 # 7
judgmentday
There are 307 automatic gasoline 1.6. It was a problem of eating gas as if knock and gear were idle in 1-2 passes and high speed pass in 3-4 passes. After long investigation, I said to the service, the transmission revision. I will write to you the situation that I will receive the vehicle in 1-2 days.
08.05.2020 18:49 # 8
dream
[QUOTE = hasanucar] sa I am the first to hear the seloneids need to change when the snow and sports lamps are flashing, and I have something in my car; There is another gap between N and D in gear, so when I slowly pull from N to D, if I do not pull the gear fully and leave it in that space, the sports and snow lamps are flashing. This is always the same. But if I throw the guy d smart or if I pull it directly to the 3, there is no problem ..
Always have the transmission oil checked before operating your vehicle.
08.05.2020 18:49 # 9
enes_468
friends no more comments ????
08.05.2020 18:49 # 10
enes_468
Is there anyone else who has experienced this problem other than me? ??????????
08.05.2020 18:49 # 11
enes_468
friends, sports or snow lamp does not change celeonites ?????????
08.05.2020 18:49 # 12
Foxfire
Brother, your problem is the position switch, which is caused by the switch located on the gearbox, so there is a simple operation that you need to make a simple operation. Adjustment is required when in the N position
@ hasanucar1 Foxfire 2014-10-19 12:44:16
08.05.2020 18:49 # 13
enes_468
enes_468 2014-10-20 00:41:27
08.05.2020 18:49 # 14
hasanucar
[QUOTE = dream] [QUOTE = hasanucar] I am the first to hear that when the snow and sports lamps flash, the seloneids need to change, and I have something in my car; There is another gap between N and D in gear, so when I slowly pull from N to D, if I do not pull the gear fully and leave it in that space, the sports and snow lamps are flashing. This is always the same. but if I throw the guy d smart or pull it directly to 3, there is no problem ..
[QUOTE = Foxfire] bro you need to adjust the position switch originating from the switch located on the gearbox, so there is a simple operation you need to do it yourself, there is a small plastic screw in the spring region open it Adjust it so that it does not remain. Setting is required when in the N position
@ hasanucar [/ QUOTE]
At the first opportunity, I think there is no situation to be traded as well, because it is a miracle .. I think it is necessary to hold the gear and pull it down very slowly. It is not a problem because we pull it directly to D. @Foxfire thank you for your information, I can not collect if I disassemble, but I can see if I find a space anyway :)
hasanuc is 2015-02-01 17:51:15
08.05.2020 18:49 # 15
enes_468
we are opening a subject folks discuss the issue on my page.
08.05.2020 18:49 # 16
enes_468
What happened to my buddy in the judgmentday ? enes_468 2014-10-24 21:56:59
08.05.2020 18:49 # 17
enes_468
There are no jobs in this forum. the big peugeot form man is intelligent.
