Automatic Gear Fault SOLUTION
08.05.2020 19:27 # 1
karambol14
"Automatic Gear Fault" malfunction 2004 model 307
Hello friends..
If your car gives an error like - * s on the screen display when it gives this error and
Do not be afraid if your vehicle is shifting gears normally and going back and forth unconsciously or slowly ...
Remove the sheet of hair underneath the battery ... there is an electronic circuit to show the screen which gear is in the vehicle and the vehicle operates in modes with the information it receives from here.
When you move the gear lever, you will see the plastic container with the circuit
definitely by checking the position of that box and remove it if you put it back.
You will see two screws attached to the torque star and loosen the handle coming from the inside with 10-11 wrench before removing them.
Then, unscrew the TORK screws and open the box and open the plastic box slowly.
REMOVE FROM THE PLASTIC BOX WITHOUT DAMAGE TO THE ELECTRONIC CARD BEAUTIFUL CLEAN WITH THE ELECTRONIC CARD CLEANER PRODUCTS ON SALE (or pour 2 cans of pads in every panacea)
Everything is beautifully clean off after the guards with gresyag create a layer of thin electronic card where the circuit channel
If there is no gasket around the cover, seal it by making a gasket from the package rubber .
If you press silicon, you cannot open it any other time .
08.05.2020 19:27 # 2
seduray
Very valuable information. Thanks.
What exactly is the task of the cleaned parc? Error. Should it be checked whether it is oxidized or not?
08.05.2020 19:27 # 3
talip206
If you still get this warning after solenoid replacement, you can try. Thank you beautiful sharing
