automatic gear fault malfunction
08.05.2020 21:26 # 1
hknzed
My car 2005 MODEL PEUGEOT 307 ...
1.6 16W XT PREMIUM PACK
I got a gear fault malfunction, I would be glad if friends who know the solution help. location istanbul sefakoy if you know a good master in this environment
08.05.2020 21:26 # 2
ismailkaya
I do not understand much, but let me comment, the gearbox-related hydraulic block failure valves may not pass the oil well from the sediment of the oil, there may be a pressure error. Electronic valves need to be changed or make the take-away tool complete. Take it to a good automatic gearbox. Or take it to the service and get a price quote
08.05.2020 21:26 # 3
EmSul
I also have the same vehicle and the same problem.
If you have to connect to the computer and look at what the transmission gave you, if it is a pressure problem, there is a problem with oil solenoid or hydraulic block. Oddly, I changed the solenoids 5 months ago.
08.05.2020 21:26 # 4
EmSul
I have now connected the vehicle to the pc but there was no pp2000, I was connected with delphi, the oil aging counter was 2028 mis 32000 and the error codes are
Oil pressure regulation interval
Engine tarku CAN intermittent
Vehicle speed signal error intermittent
I think I had to change the solenoid 6 months ago, and I actually changed the oil and try it out.
08.05.2020 21:26 # 5
mehmetgldgn
Hi ;
Other faults in the vehicle, except for the oil error, are generally seen in skidding caused by snow or ice during the cold winter months, and when the selanoids change in relation to the oil pressure error, it should be coded with pp2000 software. I believe it will be solved by coding
mehmetgldgn 2020-02-18 21:49:33
08.05.2020 21:26 # 6
EmSul
Is there any authorized service that you would recommend for solenoid replacement in Izmir or Bursa?
08.05.2020 21:26 # 7
ismailkaya
ŞANCELİK in Bursa is on the right when you come by Balikesir. There is a small industry on the same road. There is a place called Eurorepar in the room industry. They make the fault detection and get the price for you. If it is appropriate, you get the cost of the fault detection if it is expensive.
08.05.2020 21:26 # 8
EmSul
Well, anybody in Sancelik or Baykar having a solenoid change?
08.05.2020 21:26 # 9
mufit sarikaya
I got the same error. you can pay attention to the following.
1- If the vehicle is LPG, the error is increasing
2- Always replace the gearbox position switch. aliexpresste is sold at affordable prices.
3- In addition, if there is a backfire in the slope, it may be time for revision.
Since I didn't want to deal with any of them, I bought a zero transmission.
08.05.2020 21:26 # 10
muzzy35
I used a gas additive when I was on the long road, it seems that a substance in them causes the gas to burn hotter, because the engine gets very hot, it gives me this error, it gets better when I cool it. keep yourself informed
08.05.2020 21:26 # 11
EmSul
How did you know that the gearbox was protecting it because it got warm? Was there a temperature error when you connected it to the computer? I do not think that the gearbox fails directly with the temperature when I have not heard such a mistake until now, because when it fails, the gear oil temperature in the computer must be above the limits, but it does not be so high, at least in my vehicle, but the pressure drop due to hydraulic block or solenoid drops below the limits due to the change in temperature. So the problem is not warming, not pressure loss, this is hydraulic block or solenoid problem, preventing warming not only gives error, but in fact when the problem is cold, we can understand this by looking at the pressure values.
08.05.2020 21:26 # 12
muzzy35
I know from a transmission master in Bostancı, I know from there, (I guess) it's pressure related. Maybe it could be him
08.05.2020 21:26 # 13
EmSul
pressure drops but does not increase
08.05.2020 21:26 # 14
muzzy35
the problem may not be the same, I am not telling it as a master, I am researching it as well.
