Automatic Gear Fault failure
08.05.2020 20:08 # 1
KaanU
First of all, hello, I just joined you and I joined well. When my 2003 model 307 xr was driving on the road today, it gave Automatic Gear Fault error, the gear returned to high speeds and returned to normal when I stopped and restarted the car. This incident happened to me again 1-2 months later, I did some research but I couldn't find the answer clearly. What is the solution? I am expecting that if there is such an incident happening with the knowledge, it will help. Thank you from now. Have a nice day. kaai the 2017-01-23 10:46:07
08.05.2020 20:08 # 2
First of all, this error of the vehicle, which is welcomed, will be faced with the malfunction of the solenoid valves and its replacement will be improved. cost is around 600-700 rubles.
08.05.2020 20:08 # 3
KaanU
Thank you bro, thank you for informing
08.05.2020 20:08 # 4
peugeot murat
CONNECT TO PEUGEOT ORIGINAL DEVICE IF THE PRESSURE-ADJUSTMENT-DIFFERENCE-RECOMMENDED TO A FAULT
2574.16 PART CODE TRANSMISSION SOLENOID VALVE 2 PIECES
MOBILE LT71141 4 LITER GEARBOX OIL OUTPUT VALVES WHITE SOFTET SOFTWARE UPDATE SOFTWARE
