Automatic Gear Fault 'failure 2004 model 307
08.05.2020 21:10 # 1
Tal3zz
Hello, I am new in form 307 1.6 2004 I have a semi-automatic vehicle last summer when the hill was rising in hot weather, the temperature was rising, the gear was malfunctioning and it was only allowed to use in snow mode. It is connected to the machine and a warning is called oil pressure error. I would be very happy if it gives information that there is a friend who has happened before and solved the problem.
08.05.2020 21:10 # 2
Frt-Aydin
If you get pressure error and burn in snow and sport lights, you changed your oil too
It may be caused by solenoids.
I personally witnessed a master, the same you gave your mistake, the man changed the solenoids and still gave the same error.
A new team bought a solenoid, introduced it to the brain without running it, erased the errors and the problem disappeared.
I would say it would be more beneficial for you to have your job done by giving the master some money.
08.05.2020 21:10 # 3
Tal3zz
Thank you very much, in a few forms and as you said, there are 2 sets in the form of a selonite, as I said, I changed it and made it on the computer as soon as possible. I will make it as soon as possible.
08.05.2020 21:10 # 4
First of all, our friend made the necessary explanation for the transmission. There may be two reasons for an airbag error, one is the headlight signal arm, the airbag coil - the second is that if the seat has an airbag, the cables in the vehicle under the seat may be broken.
08.05.2020 21:10 # 5
talip206
[QUOTE = Tal3zz] Thank you very much, there are a few forms and 2 sets of pieces called selonite as you said, I changed it and made a computer as soon as I made it, I will make it as soon as possible. come and kiss [/ QUOTE]
In addition to the soner, remove the bottom plastic of the steering wheel, there is a brown socket on the right side, and it may fail when you loose it. Let's disassemble it and put it back on.
08.05.2020 21:10 # 6
Tal3zz
First of all, I liked it and thank you very much for your interest, I will make a written application on the 15th of the month. Is there a good master or service you can get ???
